Tool Talk Discussion Forum
Submerged DC motor
Smith Cotton
03-25-2007 10:34:56
Will a DC motor operate when submerged and full of water (trolling motor)?
Randy SE-MN.
03-26-2007 02:48:55
 Re: Submerged DC motor in reply to Smith Cotton, 03-25-2007 10:34:56
All automotive fuel injected in-tank pumps are dc and spend their lives submerged in fuel. The B+ terminals are not insulated, and they do not short out. As a matter of fact, the fact that it is submerged in fuel is what keeps the motor runnung cool. it is further recommended by all manufacturers that the tank be kept at half full or better for the longest pump life.
IH2444
03-26-2007 06:08:10
 Re: Submerged DC motor in reply to Randy SE-MN., 03-26-2007 02:48:55
The little pump motor itself seems to be sealed though. 12V DC will not leak a lot co current toru most liquids, not a high enough voltage.
run a 120 volt pump back there and watch the boom though :D
buickanddeere
03-25-2007 18:55:16
I seen a 200HP 600V open frame fan cooled pump motor running for days fully submerged in lake water. Never did burn or short out. Punped the sump dry and put a blower next to the motor for a few days. It meggered over 10 meg ohms.
msb
03-25-2007 18:19:55
Used to make trolling motors out of heater fan motors. They would work for a long time. Usually a whole fishing season in fresh water.
Dave Anderson
03-25-2007 18:04:23
Mythbusters had a dc power window motor submerged for a half hour or so, and it still worked, even under water.
old
03-25-2007 13:06:48
Would you believe that a trolling motor is sealed so that water will not get in to them. I usto work on trolling motors and found that you had to have the correct seals etc if you opened them up. And yes they will work for a little while but not for very long
Coloken
03-25-2007 11:27:04
For a little while.
Pooh Bear
03-25-2007 11:00:04
It will work as long as all the electrical parts are sealed up water tight so water can't get into them. Otherwise it will just short it out.
Pooh Bear
