Plastic radiator tanks.,
Gene Davis
05-05-2001 15:39:35
Has anybody out there been sucessful in repairing a crack in one of these @@#$%%^%*%**!!plastic radiator tanks if so how?Thanks for any help you might have to offer! Gene
Steve U.S. Alloys
05-06-2001 19:10:50
 Re: Plastic radiator tanks., in reply to Gene Davis , 05-05-2001 15:39:35
We have experience with welding plastic, Gene.
The type you want to repair is not a difficult one. The welder needs to develop the proper amount of heat and the filler material has to be of the same type as the base material.
Proper procedure should be followed so the filler or the base are not overheated. Heat only until the filler "sticks " to the base. The filler will retain it's shape throughout the operation. Slight pressure applied to the filler forces it into the prepped area. The filler will not flow like a brazing rod. Proper filler diameter is also key.
Sometimes the base material is rotten and the molecular structure has changed enough that repairs are difficult. This is true of both metals and plastics.
rhudson
05-05-2001 22:54:56
Hi Gene,
i carried one to a rad repair shop a few years ago. he said he could repair some cracks with what look like a hot gun glue stick and a hot air torch. but he replaced my tanks with new ones. takes a crimp and uncrimping press to put new tanks on. don't you just love plastic in a metals place?
Aaron
05-05-2001 19:13:11
Replaced mine with a new metal one. Gave the old plastic tank, aluminum core one to a demo derby friend of mine. Give me copper.
Aaron
