Tool Talk Discussion Forum
Somewhat OT: Paint sprayer or brush?
Kent in KC
03-20-2007 08:59:03
Mornin, fellers (and fellerettes). I am preparing to paint my house interior, stem to stern (with latex, all rooms the same base color).
I plan to use long handled rollers for most of it but first I need to cut in the corners. Normally, I'd use a 4" brush to edge in with but I'm getting older and there's oh, so many of them. So, I'm pondering renting an airless sprayer. Any agrees/disagrees?
If I rent the sprayer would it make sense to just spray the whole dang thing and skip the rollers? It is new construction and there is no flooring or trim yet, so minimal concern about overspray.
Thanks, as always, for your advice.
Pete in Cal
03-20-2007 22:31:06
 Re: Somewhat OT: Paint sprayer or brush? in reply to Kent in KC, 03-20-2007 08:59:03
Use a good respirator with filters for the paint material you will be spraying. Don't rely on a cheap face mask, your lungs deserve better.
steve from mo - dangit!
03-20-2007 09:03:13
 Spray. in reply to Kent in KC, 03-20-2007 08:59:03
don't brush or roll anything. You've got the ideal situation for spraying. New construction, no trim, all the same color. All you need is a helper to mask the ceiling while you spray.
Kent in KC
03-20-2007 09:04:48
 Re: Spray. in reply to steve from mo - dangit!, 03-20-2007 09:03:13
Hey, I'll just spray the ceiling too (its all flat Shell White). Thanks.
old
03-20-2007 10:10:57
 Re: Spray. in reply to Kent in KC, 03-20-2007 09:04:48
Spray will take less time and less paint also. Biggest problem is you being able to breath so you need good ventalation and a good mask and be ready to have white hair for a few weeks if you don't wear a hat LOL
