Tool Talk Discussion Forum
Will straight CO2 work for wire welding ?
IH2444
03-16-2007 09:07:57
Just wondering, I can get paintballgun co2 cheap. Can it be used for shielding gas for a wire feed welder ?
135 Fan
03-16-2007 21:26:01
 Re: Will straight CO2 work for wire welding ? in reply to IH2444, 03-16-2007 09:07:57
Yes, Co2 can be used for MIG welding and in any mode. The only time you get into spray mode is when your volts are higher than around 22 or so. On a high end machine Co2 will work fine on short circuiting current. The biggest reason C-25 (Argon Co2) gas is used is because it has a slightly smoother arc and a lot less spatter. Co2 does however have a narrower bead with deeper penetration. Co2 will require a heater and/or regulator and flowmeter with a heat sink as it will freeze and gas flow will stop when doing a lot of welding. Some flux-core wire calls for Co2 shielding or C-25 shielding depending on what type of bead profile you want. C-25 has better wetting properties. Co2 for welding needs a special cylinder which is heavier because if I recall it has a dip tube in it so you only get gas coming out and not liquid. It's something like that. C-25 is more expensive but isn't as fussy as Co2. Hope this helps. Dave
135 Fan
03-16-2007 21:37:29
 Re: Will straight CO2 work for wire welding ? in reply to 135 Fan, 03-16-2007 21:26:01
I just wanted to add that Co2 at lower volts isn't completely in short circuiting mode. It's kind of in between short circuiting and globular transfer which accounts for the increased spatter. As volts go from low to high the type of metal transfer goes from short circuiting to globular to spray. Some fancy machines have pulsed transfer which gives the benefits of short circuiting and spray for higher deposition rates in different positions. It's a little confusing but Co2 can be used by itself if needed. Dave
MaddMatt
03-16-2007 18:06:05
CO2 is for sray transfer only mainly cause it cools the gun where mix will burn the guts of your gun up
Stan in Oly, WA
03-16-2007 19:37:26
 Re: Will straight CO2 work for wire welding ? in reply to MaddMatt, 03-16-2007 18:06:05
Right...except for the part about pure CO2 being for spray transfer only and the part about CO2 cooling the gun.
Spray transfer and pulsed spray transfer usually use Argon with up to 5% oxygen. Argon plus Helium or Argon plus Hydrogen are used for GMAW of non-ferrous metals.
Pure CO2 is used for globular transfer GMAW, and pure CO2 or C-25 is used for short circuit transfer GMAW.
Equipment cooling is not a gas choice consideration with any GMAW or FCAW process.
All the best, Stan
IH2444
03-16-2007 11:53:17
Thanks for the replies, this is what I needed to know.
Mike M
03-16-2007 10:29:02
I use straight co2 and get by allright. It last longer than the mix is what they tell me as it regenerates. On some of my sheetmetal I wish I'd of used a mix for better results.
Stan in Oly, WA
03-16-2007 10:10:34
Straight CO2 is commonly used as a shielding gas for wire welding. It is not as good a conducter of electrical energy as Argon, so increased voltage is necessary to overcome its resistance (this is a matter of physics, not an adjustment you have to make.) The increased voltage makes it a very high energy arc with good penetration. The down side is that it is somewhat violent, not so pleasant to weld with, and creates a considerable amount of weld spatter.
At the community college welding shop where I work we have wire feed welders set up with both 100% CO2 and with C25, which is 75% Argon and 25% CO2. I prefer to weld with C25 but not so much so that I pay the extra cost for it at my shop at home. At home I have straight CO2. It's cheaper and it gets the job done.
All the best, Stan
glennster
03-16-2007 10:23:58
 Re: Will straight CO2 work for wire welding ? in reply to Stan in Oly, WA, 03-16-2007 10:10:34
the bulk tanks for paintball co2 draw from the bottom of the cylinder, you will get a liquid co2. the have a long tube inside the cylinder from the valve to the bottom of the tank.
