Tool Talk Discussion Forum
Hose crimping machine for 4 braid
BSer
03-14-2007 17:34:14
have several machines with hi pressure hydraulics that require 4 braid hose. No one within 50 miles does it. I'd like to buy my own crimper and stock what fittings we use. What is a good source of fittings and hose? I'm in Florida so shipping is a consideration. used machines are cheap on E-bay but I want to match it to the supplies I can get. Any ideas?
Cliff Neubauer
03-15-2007 09:34:43
 Re: Hose crimping machine for 4 braid in reply to BSer, 03-14-2007 17:34:14
You might check with your local auto parts stores to see if they could set you up. I talked with one of our's a little bit about it last spring, they were looking at changing suppliers and with the new supplier they were looking at (I think it was Goodyear) when you bought a new crimper for every dollar worth of fittings and hose that you bought they would take half a dollar off the price of the crimper. I didn't look into it far enough to get actuall prices but the numbers the salesman threw around made it look like that by the time a person bought enough supplies to make it worth having your own crimper a new crimper would have cost about the same or even less than a used one off ebay.
matthies
03-14-2007 19:11:55
Check with kimballmidwest.com, we have kimball products at work and some of the other shops of ours have a portable hose crimper that you can take right to the machine and crimp on a new end once the old one is cut off. chris
caterpillar guy
03-14-2007 18:16:44
Parker hannifin and weatherhead are two companies that carry hose and fittings I'm sure there are others just suggestions could also see what AIS or some of them have to get fittings when you come across an odd ball or are out .
B BARENIE
03-14-2007 18:12:10
GO TO THE INTERNET SIGHT OF EITHER, (EATON) OR (PARKER) FROM THERE YOU CAN FIND A LOCAL INDUSTRIAL DISTRIBUTOR !
