Tool Talk Discussion Forum
Pouring concrete floor in Pole Barn
Bob in GA
03-12-2007 17:15:18
I am considering pouring a concrete floor in my pole barn for my shop (1/2 woodworking and the other 1/2 repairing/restoring old tractors and cars) I plan to put piping in for radiant floor heat. What thickness should it be and would you use both fiberglass and wire mesh in it or just one of those.
Thanks
Bob
TGIN
03-13-2007 15:05:50
 Re: Pouring concrete floor in Pole Barn in reply to Bob in GA, 03-12-2007 17:15:18
Wrap your post with 1/2 sty.fom so you dont get cracks off of them .
Ken Thies
03-13-2007 10:18:13
You can get some info. here. Best way to heat a shop.
No cold feet and when you are working 60 deg is way warm enough.
Ken
Ken Thies
03-13-2007 10:20:15
 Re: Pouring concrete floor in Pole Barn in reply to Ken Thies, 03-13-2007 10:18:13
Looks like the link got lost.http://www.radiantdesigninstitute.com/page2.html
MarkB_MI
03-13-2007 03:19:19
It sounds like MSD knows what he's talking about. You need a good solid sand or gravel bed with good drainage, with high density insulation over it, particularly around the perimeter. Don't forget to insulate the boards around the perimeter of the slab. I ripped 2" foam insulation at 45 degrees, then glued it to the boards with the taper pointing up so that the concrete tapers out to the edge.
I used mesh, which gives you something to attach the PEX to. If I had to do it over again I'd probably use rebar; the mesh is hard to work with and you have to watch your crew and make sure they lift up the mesh as you pour. But it worked OK for me. If you don't use rebar or mesh, then they make clips that stick into the insulation to hold the PEX.
I got all my radiant supplies from Mountain View Supply, by the way. Link below.
Carwash Tech
03-12-2007 21:54:16
 A SUGGESTION: in reply to Bob in GA, 03-12-2007 17:15:18
Whatever you do, don't let anyone talk you into burying a radiant heat manifold IN the slab!
This was/is a common practice in some areas, but it is a nightmare if you develop a leak later.
By having the manifold ABOVE the slab, if one loop should spring a leak, that loop can be isolated from the rest of the system.
Dal in MO
03-12-2007 20:38:14
Radiant heat works very well and is also very economical to heat with, We built our house here in north east MO. 3 years ago 2400 sq. ft. floor is 4 inchs of 4500 psi concrete 1/2 rebar on 16 inch centers, 1/2 inch pex for hot water heat over thermo foil (rated at 15R) and 10 inches of 3/4 inch rock under foil. heating water with a standard electic 40 galloon water heater. Our highest electic cost for heat was in febuary of last year of $137.00 for heat, averaging $445 for the year. good luck with your project
Dal
MikeCatthemuseum
03-12-2007 19:40:55
I just did this a couple of years ago. Forget the wire mesh. It's hard to keep in right place in the slab (wants to float up or sink) and costs about the same as #3 (3/8") rebar, which is FAR better. I went 4000lb mix and fiber reinforced on a 6" slab. No idea on the slab heating. Not worth it for the temps around here in my opinion.
Chad Franke
03-13-2007 06:25:20
 Re: Pouring concrete floor in Pole Barn in reply to MikeCatthemuseum, 03-12-2007 19:40:55
How many #3 rebars do you put in in place of the mesh? I like rebar better than mesh, is it every 16 inches on center? Thanks.
MikeCatthemuseum
03-13-2007 22:35:43
 Re: Pouring concrete floor in Pole Barn in reply to Chad Franke, 03-13-2007 06:25:20
Chad, I have a friend who is an engineer with lots of good sense. He was the one who suggested to use the rebar instead of mesh. I tied mine with some leftover stainless electric fence wire that was left in the shed by the previous owner. I blocked it up 2" off the bottom on piece of brick, cinderblock, rocks and whatever was handy. Rebar or mesh does no good if it goes to the top or bottom of the slab. Mesh floats, sinks, or gets walked down to the bottom during the pour. Rebar stays where you put it. 16" centers is just fine... but here's an even better way.
Concrete cracks at the edge. If you can keep the edges from cracking, it's probably not going to crack. This means your rebar needs to be biased towards the edges. Out on the edge of the slab, my first two courses of rebar are on about 6" centers. The next couple are on about 9" centers, then 12" centers, then 16" centers, then 18" centers and so on until the middle of the slab where it's about 24" centers over about 6 or 8 squares.
I also put a bunch of leftover 5ft pieces in the doorway of the bay, where I pull my cars, trucks, (and eventually tractor or whatever) in and also where I unload my machine tools. It's about 10" centers over a 10x10ft area there.
The cure was slow and, being inside, was nice and damp the entire time. The finisher did a marvelous job, leaning a glassy smooth floor, but one that is not even the slightest bit powdery. After he finished, he told me to go buy some curing sealer and mop it on, which I did. No weight other than my feet touched the surface until after 30 days.
After the cure, i beagn moving stuff back in. I have a 6000lb lathe, a 6000lb radial drill, a 4000lb mill and a couple of other small machines on one 12x30ft end of the 30x36ft slab. All came in through the big doors and were rolled across the floor on pipe rollers. No cracks whatsoever after two years.
However you pour your sab, DO NOT cut corners to save money. I did my own grading and forming, which saved a lot of money, but I spent the money on rebar, 4000lb mix, fiber, and a professional finisher. You might screed off your driveway solo, but a nice level shop floor is no place to learn the fine art of smooth finishing concrete.
As for thickness, I went with 5" (I think I mistakenly said 4", but it's 5). I was looking for info for how thick a slab should be on the net and hit an Army site that suggested a 7" slab for a TANK SHOP. Not planning on working on 120,000lb tracked vehicles, I decided that 6" would be waaaayyy plenty at that point and figured 4 would probably suffice. I then hit another site on driveways that said a 5" slab was a really great compromise.
Apparently from 4-6", there isn't a lot of difference in strength and 5" is not that much more expensive than 4" while yeilding nearly the stregth of a 6" slab... a difference that is made up with 4000lb mix, rebar and fiber at far less cost. So far, so good.
Leland
03-12-2007 18:20:33
go to www.windtrax.com they sell the tubing and manifolds to go with floor heat this is a car wash supply company
city farmer
03-12-2007 18:18:06
i am in the plumbing bus but have done some radant heat jobs on very large freezers and in some houses here in my area in fl the freezers were pex pipe on a sub concrete floor then insulation and concrete pour on top the house i did was pex pipe in sand then concrete poured on top 4 inch thick it was heated by a hot water boiler and worked very well in the house the temp went from low 50s to 75 over night very impresive being the house had no outher heat and was being heated for the first time check out pex pipe for this use
Bill in NorthCentral PA
03-12-2007 17:57:37
The jobs I"ve done were fine graded with clean stone, 6 mil plastic vapor barrier, 2" rigid insulation 4" around perimeter with 1" rigid under whole floor, with welded wire mesh (WWM) sheets. The tubing gets wired to the WWM and the concrete is poured. 6" is a minimum thickness with pipes I would think. Air up the pipes when pouring the floor. We wheel the concrete right over the pipes. Never had one break, but I"ve heard they are real easy to find with the air pressure blowing out. If I hired a heating contractor (50% of the time), I had them send one man while the concrete was being placed.
Good luck.
Bill
mjbrown
03-12-2007 17:27:53
Better do research on the web on radiant heat and make sure what reinforcement is compatable with the tubes. If you get it wrong it'll be hard to fix!
Bob
03-12-2007 17:45:11
 Re: Pouring concrete floor in Pole Barn in reply to mjbrown, 03-12-2007 17:27:53
Lots of folks put the tubing in a layer of sand BENEATH the concrete.
MSD
03-12-2007 20:55:58
 Re: Pouring concrete floor in Pole Barn in reply to Bob, 03-12-2007 17:45:11
We grade the subfloor with at least 4" of sand or gravel. Pack the heck out of it. 2" of rigid foam insulation and lay the Pex tubing on it. In house basements we go 4" of 3500 to 4000 mix. In shops a minimum of 5". We quit using steel mesh along time ago. It ends up on the bottom anyway most of the time if the help doesn't stay with pulling it up. Also quit using fiber mesh. Rerods are probably the best way if your worried about cracks. It might still crack but the pieces hold together better. I feel the most important thing is to get a good base before you pour. No topsoil or grassy soil and atleast 4" of gravel packed as tight as you can get it. You can drive the cement truck on ours when we get done and it leaves no tracks.
