Tool Talk Discussion Forum
Wagner Airless Sprayer
Slowpoke
03-11-2007 12:24:30
My brand new rebuilt, old stock, never used, out of warrantee Wagner airless does not prime. The inlet valve is free, the outlet valve is free and the diaphram moves, but not much. There is no adjustment on the diaphram pushrod. The question is how much oil should be in the cavity behind the diaphram? There is a small amount at the bottom of the cavity on top of the piston when machine is laid on it's back. Should there be more oil behind the diaphram? Does the oil help to move the diaphjram or is it only for lubricating the pump piston? What kind of oil is used?
Thanks
Bob in GA
03-11-2007 18:42:26
 Re: Wagner Airless Sprayer in reply to Slowpoke, 03-11-2007 12:24:30
I have the same problem but with a used unit and I have never worked with one before. I Can"t even give a model number since it has all ready been moved to my new home in NC. My question is how can you tell if the diaphram is moving. What do you take off to tell?. Mine was out of oil and I put JD HyGard in it. Should I remove it and buy Wagner Hydraulic oil?
Thanks
For the help
Bob
Slowpoke
03-12-2007 00:08:06
 Re: Wagner Airless Sprayer in reply to Bob in GA, 03-11-2007 18:42:26
Removing the inlet valve (where the paint enters) allows you to see the diaphram. Put the eraser end of a pencil in the opening and you can feel the diaphram pulsing when the motor runs. I don't know if the HyGard oil is suitable or not.
Chris Parrish
03-11-2007 12:28:36
Use wagner hydraulic oil and the resevoir should be oil should run out when you take the plug out with the unit standing up. You will have to bleed the hydraulics. This is not a "piston pump" it is a diaphram pump. Email me this is what I do for a living and I will try to help you out.
