Tool Talk Discussion Forum
6.5 diesel running hot
Nebraska Kirk
03-10-2007 21:08:44
I have a 1995 Chevy pickup that is running hot. I just put a new engine in it and the first time out it was running about 240-250 degrees. I thought it had a bad thermostat, so I replaced it, but still the same problem. Funny thing, when the temp gauge says 250 degrees, the coolant in the reservoir where you add the coolant, is still cold. I did put on a new temp sender when I installed the engine. This is my first experience with the 6.5 diesel, so other than a faulty temp gauge, I don"t know what could be wrong. I would appreciate any advice you fellows can provide.
Jerry Coulter
03-12-2007 14:23:38
 Re: 6.5 diesel running hot in reply to Nebraska Kirk, 03-10-2007 21:08:44
I had that trouble on my 1993 6.5L after I replaced a failed sending unit with a new one from a parts house. So I tried one from another parts house. Same problem. Then I bought an AC-Delco part from a GM dealer and the problem was cured.
Nebraska Kirk
03-12-2007 18:22:44
 Re: 6.5 diesel running hot in reply to Jerry Coulter, 03-12-2007 14:23:38
Hmm, I will give that a try. I purged all the air out of the system, checked the ground connections and still the temp gauge showed 250-260. So I screwed in a mechanical temp gauge and it showed just under 200 degrees like it should.
jdemaris
03-11-2007 07:30:01
I don't know what you are calling a "new" engine. I also don't know if your engine is actually running hot - or you've got a gauge/sensor problem.
If you find that it IS hot, check the upper radiator hose when running by squeezing it. If it's hard - i.e. gettting pressurized - you may have a head-gasket and/or cracked head problem. The 6.5s crack stock heads pretty easy. The new heads being made now (in China) are a huge improvement over the stock heads - much thicker castings, hardened valve seat inserts, etc.
Bob
03-10-2007 21:45:37
The temp sensor for the gauge is near the front of the LH cylinder head sticking out towards the LH fender.
Is that the one you replaced?
Are you SURE you got the correct part? A friend just went through something similar with a 1994 and wound up returning the "parts store" heat sender and ordering one from the GM dealer by "vin" number.
The other thing to check that will cause ALL SORTS of strange problems is that you have ALL the ground wires connected to the engine.
IIRC there may be some ground leads at the back of one or both cylinder heads and on several intake manifold bolts/studs. These ground leads may extend from the wiring harness or be braided ground leads from the metal of the cab.
Nebraska Kirk
03-10-2007 22:37:24
 Re: 6.5 diesel running hot in reply to Bob, 03-10-2007 21:45:37
Yes that is the one that I replaced. I think it is the correct one. It looks identical to the old one.
I will check the ground straps. Come to think of it, I remember seeing a small braided cable hanging on the right side.
Thanks for the tips!
Bob
03-10-2007 21:48:13
P.S.
Make sure ALL air has been purged from the engine.
Does your's have the air vent screw in the thermostat housing?
Nebraska Kirk
03-10-2007 22:31:44
 Re: 6.5 diesel running hot in reply to Bob, 03-10-2007 21:48:13
Yes it does. Does that screw have to be opened while the engine is running to purge the air? I never gave that a thought.
Stumpalump
03-10-2007 23:19:32
 Re: 6.5 diesel running hot in reply to Nebraska Kirk, 03-10-2007 22:31:44
Yep.
Stumpalump
03-10-2007 23:31:08
 Re: 6.5 diesel running hot in reply to Stumpalump, 03-10-2007 23:19:32
Here's a link to to update your cooling to the 97 and newer parts. Copy and past link. Link
