Tool Talk Discussion Forum
portable generator
russ hamm
03-10-2007 08:25:51
third party image
just got done with it this morning. an onan generator out of a motor home/ international baler engine gas tank and those dang doughnut spare tires.
Tim Casbolt
03-10-2007 14:31:40
 Re: portable generator in reply to russ hamm, 03-10-2007 08:25:51
Nice job! You should post it in the completed projects section of machinebuilders.net. If you ever want to convert it to propane, propanecarbs.com carries a conversion kit for most Onan's. Eliminates the problems associated with engines sitting around for long periods of time.
Roy Suomi
03-10-2007 14:28:40
Looks good...The only thing I would change is larger mufflers , less back pressure....Other than that very ingenius....
buickanddeere
03-11-2007 04:39:02
 Re: portable generator in reply to Roy Suomi, 03-10-2007 14:28:40
Tail pipes after the mufflers will cut the noise even more. Looks like there is room to curve a couple feet of pipe down towards the ground. A respectable looking outfit.
Jon Hagen
03-10-2007 08:53:32
Looks good, you turned a lot of scrap parts into a very usefull device. I bet that RV genset only runs 1800 rpm too, Much more calm running and much longer lived than the 3600 rpm units that are sold on price alone.
