Tool Talk Discussion Forum
PTO Shaft
KY Tom
03-09-2007 23:46:05
I purchased a used Eversman Tiller at auction and I am in need of a 1 3/4" male, 21 spine, 540 rpm, shaft that hooks to the tractor. Any information where one of these can be found new or used would be appreciated.
Tim Casbolt
03-10-2007 14:34:59
 Re: PTO Shaft in reply to KY Tom, 03-09-2007 23:46:05
Tractor Supply Company is a good resource for pto accessories.
paul
03-10-2007 08:11:11
Do you mean the shaft itself is splined - not a 3 or 4 sided tube, but a many-splined shaft? My brother in law has one of those on one of his implements. Never saw that before, might be a rare thing.
Or, do you mean the yoke/ coupler that connects to your tractor is 21 splines? Typically that is reserved for 1000 rpm drivelines. So needing it for a 540 pto is kind of a puzzle too.
--->Paul
ihcjdall
03-10-2007 07:37:19
alot of times shops that make or repair truck drive shaft's can make you one alot cheaper than a new equip. dealer will. you can as stated before go to tsc or rural king and get about any of those parts cheaper. my local tsc sells weasler shafts and parts that are the same as j/d uses when they make one.
JD9295
03-10-2007 07:11:51
if you need the 21 spline then you need the gearbox end or your pto on your tractor is 1000
TSC or any farm store, all tractor dealers will have them
J Schwiebert
03-10-2007 05:00:50
I am confused. 21 spline is for a 1000 RPM PTO. I also sent you an-e-mail
