The rear cylinder cracking problem was bolt-hole depth related and happened in the military and civlian versions. The more serious problem - more common with the older 6.2 blocks - it the block cracking at the main-bearing webs. According to GM and the US Army, there is no such thing as a "military spec." block - but the accessories are. In regard to the Humvees - they were the opposite of detuned. The military tried to boost the power to cope with all the added weight from added armour. I have the fuel-delivery specs for every miltary 6.2 and 6.5 used - and they are never less than civilian, usually more. For example, a 1990 6.2 in a Humvee pumped a max. fuel charge of 50-51 mm3/stroke. A 1990 civilian highest-output 6.2 (J-code) was set at 48.5 mm3/stroke (less then the military) In regard to the high-rate of failures of injection pumps - the military versions don't have the sensors that often fail on civilian 6.5s with DS4 pumps. The failures are all mechancal - due to very hot engines, hot air, and thin JP8 or Jet A1 military fuel. For the Humvees in Iraq, extra money was spend on the Stanadyne optional thin-fuel "arctic" package - and according to tests - it made no difference. Any pump that has "1.2 cSt" stamped on it has the kit. Here are portions of a couple of articles that addressed this in the past (not my writing). " . . With the recent major combat operations in Afghanistan and Iraq, fuel-related problems have increased significantly as a result of using low-viscosity fuels as the single fuel. In Afghanistan, much of the aviation kerosene that initially was procured was Russian TS1 aviation kerosene because the neighboring refineries produce aviation kerosene as TS1 instead of Jet A1 or JP8. The Russian TS1 aviation kerosene is similar to Jet A1, but it is more volatile because it has a lower flash point and a lower viscosity. The fuel being used in Iraq is JP8. However, in both Afghanistan and Iraq, the ground vehicles and equipment are being used much more extensively than they would be used in normal service. Considering this added use, the hot temperatures that typically prevail in the Middle East, and the increasing engine-power demands imposed by the increased weights of up-armor kits, it is no wonder that the ground vehicles and equipment that have rotary-distribution, fuel-injection pumps have had many fuel-related engine problems. " And another: " July 2004 issue of National Defense magazine, Army Ponders New Diesel Engine for Humvee Trucks," notes that maintenance nightmares have been experienced in Iraq because engines regularly break down and often must be replaced after only 1,000 to 2,000 miles of operation. Much of the blame for this is placed on the bolted-on armor protection that adds weight to the vehicles. However, the inability of the rotary-distribution, fuel-injection pumps to operate satisfactorily for sustained periods of heavy-duty operation is probably a contributing factor, especially when low-viscosity fuel is used in a hot environment. Interestingly, the fuel-injection pumps in many, if not all, of the HMMWVs operating in Southwest Asia have been retrofitted with Stanadyne's Arctic Fuel Conversion Retrofit Kit. This kit apparently has done little to offset the significant increases in maintenance that have been experienced recently. Combat operations that occur in higher temperature environments certainly will intensify the operational and maintenance problems of diesel-powered vehicles and equipment with fuel-lubricated fuel-injection pumps. Since almost half of the Army's diesel vehicles and equipment have rotary-distribution, fuel-injection pumps, a solution is urgently needed. "
