Tool Talk Discussion Forum
hole saw tip
j-tex
03-07-2007 07:39:59
Maybe this tip can save someone some of the troubles I had with a hole saw.
I was drilling out some 4-1/2 holes for some trailer lights but the saw kept grabbing and snapping the pilot bit. Once the pilot hole is driled it is only there for a guide anyway so I cut me a peice of 1/4 rod and used that as a pilot/guide in my mandrel. Worked out real well
J-tex
Kent in KC
03-09-2007 10:10:38
 Re: hole saw tip in reply to j-tex, 03-07-2007 07:39:59
Drill the pilot hole first. If you use the pilot drill that comes with the hole saw, after the pilot pushes through the material, the hole saw will drop down and grab the material, sometimes breaking some teeth off the saw. Pilot the hole first with a regular drill bit, then ease the saw down and start cutting smoothly.
Mulesandheelers
03-08-2007 09:11:48
"so I cut me a peice of 1/4 rod"
Here is a link to 3' of the type of rod, that ought to be used.
mulesandheelers
03-08-2007 09:27:33
 Re: hole saw tip in reply to Mulesandheelers, 03-08-2007 09:11:48
For some reason the link is coming up on other sizes instead of 1/4". This runs $1.59 or $1.79 apiece.
Model# FW409-0013 & FW408-0013 for search.
Oldmax
03-08-2007 05:49:33
I drill holes with a drill press before welding metal in place Is much easier than with Hand drill
Clamp metal in drill press then you don't have to worry about it breaking bit .
j-tex
03-08-2007 06:13:19
 Re: hole saw tip in reply to Oldmax, 03-08-2007 05:49:33
I agree it would be easiest to do in a drill press, but this is on a existing trailer. cant get it in the drill press :)
fixerupper
03-07-2007 19:34:19
Very good idea. I was having the very same problem A while ago while cutting out tail light holes. I'll give your ides a try next time. Jim
NC Wayne
03-07-2007 18:02:06
Don't remember where I saw it but somebody is making a setup that you can use to enlarge a hole. Basically it used the origional size hole saw as the pilot as well as having the larger size one to cut the new hole.
`Bernie in MA
03-07-2007 17:20:52
That's good. Another thing to do is saw a hole in a piece of scrap and clamp over where you want the hole and use it for a guide instead of the pilot drill. I did this on a flat cast iron pulley that had a broken off allen setscrew in it.
Bud in NC
03-07-2007 17:10:45
(*SLAP* to my forhead!) Sure wish I'da thoughta that years ago!!!!! Thanks!!!
flying belgian
03-07-2007 08:52:11
Thats a good idea. Thanks for posting.
