Tool Talk Discussion Forum
What to look for in air nailer and trim work
ShepFL
03-06-2007 17:50:04
Mrs. ShepFL has given me an ultimatum to finish her crown molding before I get really cranking on the tractor work.
I am a shade tree carpenter so any good links on how to install 3 step crown molding? Also looking a getting a light duty air nailer (brads? staples?) so I do not ding up my work.
What to look for on this tool as it is more complicated than my hammer!!
Thanks
nballen
03-08-2007 07:39:40
 Re: What to look for in air nailer and trim work in reply to ShepFL, 03-06-2007 17:50:04
Shep,
Something to look for is a padded saftey bar on the trigger/tip.
When working on my house last year, I used a Harbor Freight and a Porter-Cable finish nailer.
The HF nailer had a bent wire loop that had to be depressed to "unlock" the trigger - Well, that loop left a small ding in the wood trim at every nail.
The Porter-Cable nailer had an L- shaped end to that interlock piece, the end that contacted the work piece was about 10x larger than the HF, and had a soft polymer guard. The result - No dings in the new trim!
Quality matters, and you get what you pay for.
Nathaniel
JOHN HARMON
03-07-2007 17:10:43
Any good Wood Workers Store such as Rocklers or woodcraft supply have Volumes of Instruction Manuals for "Crown Molding Installation and as far as Air Nailers I have a number of them and they all are Porter Cable Bradders from Lowes.I have no complaints with them. I keep different length Brads in different ones. Use recommended Oil in them.
alg
03-07-2007 13:36:52
Shep, i bought a cheap one from Harbor frieght,no complaints,works great.
Lincoln
03-07-2007 17:33:34
 Re: What to look for in air nailer and trim work in reply to alg, 03-07-2007 13:36:52
I bought one of those cheap brad nailers when harbor freight had them on sale for around $20. It is the best $20 bucks I have ever spent. I liked it so well my brother bought one. I can't count the number of projects we have done with these nailers and both just keep nailing away with no problems.
jjpuleo
03-07-2007 08:08:35
I own a cheepo Cambel Husfeld brad nailer. Its garbage! jams about every 30 brads. I also have a cheep import angled finish nailer. It fell apart but after working on it it has become semi-reliable. Both are fine for occasional use. I hav herd great things about the grizzly brad nailers.
I think a small brad nailer and glue will be all you need and not a finish nailer. The Grizzly one is cheep and if you decide you want a finish nailer you can always get one too.
Bud in NC
03-07-2007 03:46:21
The key to cutting crown moulding is that you put in the miter saw upside down and backwards. A coping saw will help is you need to cheat on an out of square corner.
Here's some more info -
Link
http://www.thisoldhouse.com/toh/knowhow/weekendprojects/article/0,16417,1016651-6,00.html
don t-9n180179
03-07-2007 02:07:33
Few years back, put T&G knotty pine paneling up in basement. I bought a Bostich (air) 16ga finish nailer. It worked well, aprox 5000 nails w/one jam (user error). Cleared w/o a problem. You may want to look at an 18ga. Smaller holes, a bit lighter weight, potentially less blow out if ya get the gun to close to the edge. HTH...good luck.....don t. .....
NE IA Dave
03-06-2007 19:43:25
MY first finish nailer was in excess of $400.00 many years ago. Pasload is a good finish nailer (gas powered) if you have alot of jobs and dollars. No hoses are nice, but expensive. On the larger jobs we have several air hoses scattered, so for the last four or five air powered I have been going to Wal-Mart and getting the Campbell Hausfield, If I can recal you can get a stapler, and nailer for about $60.00 for one of each.
I always run at max air pressure that the gun is rated, and probably 90% of the folks here or at a construction job will tell you to cut the air pressure so the nails do not over penatrate. Some wood or plastic you have to cut the pressure. However a nailer is no different than a piston in your car or tractor, they must make a complete cycle. Anotherwords the piston must shove the plunger to the bottom of the stroke in oreder to cycle. The better guns adjust the distance from the saftey to nailer space.
I have been known to over nail crown molding and trim, but the last several years we are leaning more on adhesive, making less nail holes to fill.
Crown molding in a miter saw-- think backwards. Make a few patterns out of scrap, and take the samples to the ceiling / wall & pencile you cut direction. Not real hard to do.
If I have to stain / finish trim we usualy place wax paper behind. If staining or finishing is required (staple with very few hand staples). This allows you to varnish, stain, or paint the trim. After all painting and triming on the walls or ceiling is done then wax paper is cut with a NEW razor blade or pulled out from behind the trim. You have to place the adhesive carefuly when using wax paper. Now if the wife is going to do the stain, varnish, painting and is being very difficult and the mother in law is helping her----- -well maybe forget the wax paper. ---Just kidding now!-- At a min be sure to stain it prior (can be sprayed if you have alot) before putting it up.
We use a sharp Lion trimmer, after the miter cut is made. No you can't afford one for a single project, but maybe a rental store has one--well worth the rental fee regardless of cost.
On the cheaper guns (and real expensive trim)sometimes the saftey will mar the wood, some have rubber caps for the saftey. Otherwise harming the trim can be controled by a helper holding very thin cardboard under the gun, and shooting the nail threw cardboard. Never let the gun jump, skid. Practice and adjust on scrap. If it does not drive the nail all the way in you may want to pull it out with a vise grip---do not pry it out as you will damage the trim. You will not regret buying one even if you never use it---they are just cool to own, and impress your buddies.
bva
03-06-2007 19:40:00
You do know that the detents near 32deg. on your compound miter saw are for makin perfect 45 deg crown cuts. get you a Senco pro 35 finish nailer.
Dug
03-06-2007 18:58:04
Just bought a couple of Rigid nailers, 15 gauge angled and 18 gauge brad. Both are great. Also picked up a portable Rigid compressor. Handiest setup I know of. Plenty of power, lightweight and if the wife has given you permission, take full advantage of the opportunity. You will NEED two nailers! And, while you're at it, might as well get the framing nailer, also. There may be a loose stud somewhere in that wall that needs to be tightened. : -)
Study the crown molding process before you get started. It can be done, but it isn't something to jump into without considerable thought...
Good luck.
PaulW_NJ
03-06-2007 18:38:49
I agree. Fine Homebuilding had a great article that I used for crown molding with many tips and techniques that was terrific. Came out perfect. The same author of the article (Clayton Dekorne) later wrote a book: Trim Carpentry and Built-Ins, by Taunton Press.
I use Porter Cable nail guns. Considerably cheaper than Senco and have worked very well for me. Yes, they"re also reviewed in Fine Homebuilding magazine.
Ryan - WI
03-06-2007 18:26:34
Insofar as nailers, shop via price. I have used them all, Duofast, Bostich, Campbell Hausfield, Penn State and Grizzly to name a few. They all work darn near the same. Some are easier than others to clear jams from but actual operation I didn't notice much of a difference. Certainly not $100 worth.
I buy my new guns now from Grizzly.
Tom R Ne
03-06-2007 18:12:15
Shep:
I will provide a link to Fine Homebuilding this is a great resource IMHO. You can search the article archives for both reviews on finish nailer's and for articles on Crown Molding.
chvet73
03-07-2007 07:22:26
 Re: What to look for in air nailer and trim work in reply to Tom R Ne, 03-06-2007 18:12:15
Here at the Woodshop in the school where I teach, we started with Bostich. They all fell apart after a few years. We switched to Porter Cable and all of those guns still work. Todays kids can wreck anything, so using my use test, PC has outlasted Bostich by about 5 to 1 in years of usage. For what that's worth. I also have PC at home and are very happy with them.
