Tool Talk Discussion Forum
window lube
coup
03-05-2007 17:27:08
i have power window that is making a bad squeak when going down,isthere anything you can get to spray on it..
glennster
03-05-2007 17:31:53
 Re: window lube in reply to coup, 03-05-2007 17:27:08
if it is the glass in the run channel that squeeks, roll the window all the way down and spray some silicone spray on the run channels front and rear, the run the window up and down a few times. if its the power requlator inside the door that squeeks, you can spray the gear and linkages with spray lithium grease.
