Tool Talk Discussion Forum
Width for building a PTO Generator Trailer
Paul (ND)
03-05-2007 13:05:13
I need to build a trailer for a 15 KW PTO generator. I have seen some homemade trailers which are very narrow (36 to 48" overall width) and have also seen some factory trailers quite wide. I have also seen some factory trailers with the PTO and hitch offset to one side. My question is: Has anyone had a narrow trailer flip over from the torque of the PTO? I would like to build a narrow trailer for storage reasons. Any other tips? Thanks.
reservedaa
04-14-2007 19:17:38
 Re: Width for building a PTO Generator Trailer in reply to Paul (ND), 03-05-2007 13:05:13
i would make the generator 3-point mounted and the make a 4 leg stand for the bottom, easy to hook up and releaves the hydraulics, kinda like a three point chipper has on the bottom.
buickanddeere
03-06-2007 15:21:30
No matter what width of trailer you build. Off set the generator to the loaded side.
ray_woods
03-06-2007 12:29:08
third party image
Here's a picture of how the electrall generator is setup.
I have a 12.5kw pto generator(electrall) the outside of wheels is not quite 4'. I only tow it via the tractor. No issues with the trailer hopping or torquing durning load startup.
Mike M
03-06-2007 06:45:36
We got a gen. from my uncle and he built a pretty big trailer,has a cord rack on the back,and a roof on top. It takes up alot of space to store and I keep thinking of makeing it smaller ,but it sure is handy to have room for all the cords and adapters and that roof comes in handy to keep the rain and snow off it since the power rarely goes off in the nice weather.
souNdguy
03-06-2007 06:01:43
I left my 12.5kw pto gen mounted to the pallet it arrived on.. i then mounted that pallet to a 3pt carryall... easy to move.. and no flip overs..
Soundguy
NE IA Dave
03-05-2007 19:12:05
Years and years ago I worked for a guy that sold pto generators, they were kind of a new thing or at least in the affordable range. I can think of four that flipped their homemade carts. And another that just sat it on some blocks. As I recall the damage in all cases was not all that bad, the cords were tore out, but totaly uncalled for. If you are interested they all tumbled the same direction. My questions for you would be. How much did you pay for the generator? How much more would it cost to make the trailer a little wider? Do you enjoy rebuilding trailers? Do you like dented up generators? Unless you dislike wide things I would consider making it wider if you factor in everything.
buickanddeere
03-06-2007 15:23:41
 ballast Re: Width for building a PTO Generator Tra in reply to NE IA Dave, 03-05-2007 19:12:05
If the trailer is only tractor towed. Ballast the light side wheel with washer fluid and/or combine rear wheel weights.
Tim Casbolt
03-05-2007 17:06:17
Why not eliminate the trailer and build a frame for it that mounts to the three-point hitch? Pictures are posted in the completed projects section of machinebuilders.net
T.K. in PA
03-05-2007 16:12:45
We have two gen. sets 25kw on homemade trailer about 4'x4'. Also a 65kw on factory trailer, which isn't anything more than an axel with 2 wheels & a hitch. Probably not more than 42" wide, never had either one try to upset.
RN
03-05-2007 15:18:06
Tow behind tractor only or maybe highway speeds? Farm has a wisconsin powered generator/welder trailer with solid axle and 15 inch ford pattern wheels. It has a short tongue and about 4 foot wide- plywood panel fits accros- tractor handles it for hauling to field, pickup takes it on roads to about 50mph, taillights visible from back so police have checked and said reflectors good enough except for interstate. Folding tongues like some snowmobile, boat and utility trailers could also save space. Camping trailer stabilizer jacks for corners or simple tube jack for tongue avalable Harbor freight about $20.00 at carner would help keep from tipping. Cheap jackstand could also be used. If you plan high speed high way travel- suggest sprung suspension, Dodge caravan axles around Bellville ,Wi salvage yard $100.00 gives wheels with tires , springs, mounting shackles, shocks. About 5 foot width between tires, can get narrower by using space saver spare wheels- about 54-56 inches I was told. Chevy Cavalier axles without springs but with wheels were going $25.- $40.00 also being used for trailers, without springs give a low utility that can load motorcycle or single snowmobile and wheels that don't blow over 45mph like some of the low $ 8 to 10 inch trailer tires. RN
glennster
03-05-2007 14:34:07
how about building some outriggers that can either telescope out or swing out and pin them. that way you an have the narrow trailer but can get a wide platform when you set it up.
Ludwig
03-06-2007 08:10:35
 Re: Width for building a PTO Generator Trailer in reply to glennster, 03-05-2007 14:34:07
My thought exactly. Mount 'em relatively high at an angle (think like an A shape when they're extended) and you could keep your narrow trailer and still have stability.
