Tool Talk Discussion Forum
Homelite 330 not oiling
drnsdad
03-03-2007 18:18:01
Hi I have an older Homelite 330 that is not oiling. The lines to and from the oil pump are open and I took the pump apart and it looks ok (no holes in the diaphram). I get oil out of th resevoir to the pump but not out of the pump. How does the oil pump get the air to work the diaphram, from a port to the cylinder or is there some other device that pumps air to work the diaphram in the oil pump?? Is there a way to prove the pump is or is not bad ?
Also does anybody happen to have an old busted clutch that I can get a spring off of ? Thanks, Robert in North Carolina.
