Tool Talk Discussion Forum
A good soot cleaner?
PAGlenn
03-03-2007 17:23:51
We had a fire at the farm house (1860) two weeks
ago. The wife and I got out in time, and the two
critters (cats) thankfully showed up OK a few days later inside the part of the house that didn"t burn. My questions is, what is a good cleaner to get the soot off of your hands. I tried the mechanics GOJO, but it doesn"t do the job. I wear rubber gloves when Iam there, but always seem to come out with sooted hands.
Jim K
03-06-2007 12:07:38
 Re: A good soot cleaner? in reply to PAGlenn, 03-03-2007 17:23:51
Lestoil straight out of the bottle will remove just about anything that you get on your hands.
And the wife likes it too.
PAGlenn
03-04-2007 16:32:42
Thanx All!!
I will try these remedy's as I will be sooting
around the place till its rebuilt.
Johnski
03-04-2007 09:55:03
Believe it or not, good ol' WD-40 works like a champ on soot and heavy grease. Soak your hands well and scrub it in, wipe off with a clean rag and then just wash your hands with soap and water to finish cleaning them. HTH Jf
NC Wayne
03-03-2007 18:41:41
Dad and I work on alot of the older cranes that use open gear lube. This stuff is mean to get off your hands. The best thing we've found is the Orange cleaner they sell at NAPA. You can get it with or without pumice and it works good either way. If you've got water available powdered laundry detergent works pretty good for getting the grime off. I've also found that Soft-Scrub with bleach works pretty good. I keep a bottle of it and a scrub brush in the shower to use on my hands if nothing else has worked.
JoeK(WI)
03-04-2007 09:20:11
 Re: A good soot cleaner? in reply to NC Wayne, 03-03-2007 18:41:41
There useta be some stuff called liquid gloves or such that you put on before messy jobs,Kinda like a hand cream.It kept the dirt/grease/paint etc from penetrating into your skin so that it washed off easier,along with the liquid gloves, later.Wasn't greasy or such when applied and"dry",didn't leave residue,fingerprints on things touched.Dunno if it's still around or not.Otherwise get a box of surgical gloves like drs wear,cheap and disposable,not restrictive.
jeffcat
03-04-2007 11:03:35
 Re: A good soot cleaner? in reply to JoeK(WI), 03-04-2007 09:20:11
There ya go! If you take a bottle of Ivory Dish liguid it is the same stuff. "Wash" your hands with it and then let them dry well. When you wash up use a good old bar of Ivory again cause it is a fat based soap. It will even take off coal soot from shovelin coal. Glad you and your kittys are fine. Jeffcat
