Tool Talk Discussion Forum
? about Husqvarna 51 oiler
Redtom
03-03-2007 13:35:48
I have a husqvarna 51 that i bought used. I took it to the dealer and had him sell me a bar and chain. It goes through oil but not to the chain. Today it tightened up good, so I took it apart. On the bar, the edge of the opposite hole where the adjusting lug/pin goes, (the one that is up, for use when you flip the bar over) lines up with the oil hole and slot in the backing plate. So the oil goes out this hole down to the adjustment slot and never reaches the little oil hole. The old bar is the same way. The only time the mounting hole is away from the oil slot so it is sealed off forcing the oil to the little hole is when the bar is adjusted out to the end of the slot. I know this is hard to visualize, but if you have a 51 or 55 you know what I'm saying. Is it the wrong bar? Its a husqy brand bar.
in sticks
03-03-2007 18:45:44
 Re: ? about Husqvarna 51 oiler in reply to Redtom, 03-03-2007 13:35:48
i don't have a real good answer,maybe take your saws bar to a husqvarna shop and compare bars?
