Tool Talk Discussion Forum
OT: Jetting a cook stove for Propane
Kent in KC
03-01-2007 17:56:10
My wife just bought a gas cook stove for the new house. We will be burning propane. Do cook stove typically come with propane jets or do you have to order those seperately? Thanks.
Kent in KC
03-05-2007 08:45:49
 Re: OT: Jetting a cook stove for Propane in reply to Kent in KC, 03-01-2007 17:56:10
Problem solved. GE says they ship the cooktop with jets for Nat Gas and LP. Thanks all for your advice.
traper
03-02-2007 18:32:44
Kent// The last sears i worked on called for fliping a part in regulator and adjusting the spud in to stop. The spud is the brass tip where flame comes use out use 1/2 inch wrench.One on each burner also in oven.I was in a fishing camp in alaska when i ran in to that problem.Guy had bought two stoves dident know what a spud was And flame dose realy get high when set for natural gas.This was three years ago.
Dick
03-02-2007 10:22:32
The last gas stove we purchased was from Sears. It came with jets to change if you were burning propane and full instructions. Real easy. Hope your wife bought one that can be converted. If not, take it back, get a refund, and when she goes shopping for another, be sure it can be converted to either propane or natural gas.
My two cents,
Dick
Kent in KC
03-02-2007 05:40:00
Thanks, gentlemen. I appreciate the advice. Stove hasn't been delivered yet, so I will check the mfr web site and see what I can find out. Shoulda thought of that first, I guess. Getting old...
TomTX
03-02-2007 05:33:03
Around here our's came set for natural gas. Had to get a propane jet conversion kit. Kit came with jets and detailed instructions. Tom
Ken B.
03-02-2007 05:12:27
As said above read your book or call the makers tip line . they are all differnt. I did service work for allmost 20 years.
Hal/WA
03-01-2007 19:24:56
If it is new, I would suggest reading the manual. If that doesn't tell you what you want to know, go to a professional who knows what they are doing.
A buddy of mine hooked up a stove that was set up for natural gas, to propane. When he turned on a burner, he had flames almost to the ceiling. No real damage done, but it sure scared him! Fixing the problem involved changing some jets and it worked fine with propane after that. Good luck!
Rod in Smiths Falls, ON,
03-01-2007 18:12:54
That depends entirely upon the stove.
Some have a natural gas/propane gas switch on them. Others have parts which get exchanged. The one we put in last summer, a DCS, CAN'T be converted from natural gas to propane or vice versa. Whatever comes from the factory is what you get, so everyone must take great care in the ordering process.
Good luck with the installation. Our gas guy had to drill through 51" of rock foundation to get the line into the basement.
Ken Thies
03-01-2007 18:11:59
We got a new one last year and it is adjustable to ether gas. No jet change just a screwdriver if I remember right. Check the book that came with it or the internet site.
Ken
rustyj14
03-09-2007 09:49:26
 Re: OT: Jetting a cook stove for Propane in reply to Ken Thies, 03-01-2007 18:11:59
Some years back, the propane regulator on my 1978 motor-home went bad. I looked at it, and it looked the same as the one on our current hot water tank (Natural gas). I asked a friend about it, and he said i could use the nat.gas type, just had to adjust the screw under the little plug. so, i installed the regulator, adjusted the jet and flame, and its been working ever since. Although, i was told by a guy who knows everything, that it wouldn't work! That was 10 years ago!
