Tool Talk Discussion Forum
Tables on a Carpenter's Square
J Schwiebert
03-01-2007 17:12:38
Get to sub for the carpentry instuctor for a few days. Had some questions of the tables on a framing (carpenter's square). Anybody have a good reference? Thanks in advance. J.
cowtender
03-01-2007 20:54:30
 Re: Tables on a Carpenter's Square in reply to J Schwiebert, 03-01-2007 17:12:38
I remeber an older guy telling me that when he started as a carpenter they had a guy from Germany that would use his square to double check his hours with his pay check.
jhill52
03-01-2007 20:28:24
I have a book that belonged to my grandfather copyrighted in 1908 called ABC of the Steel Square and its uses. My grandfather was a carpenter for many years. He always said if a man knew all the ways to use a square he could conquer the world.
Butcher
03-01-2007 18:51:40
Like Mike said, Audels is the best reference you could find. Most carpenters in this day and age dont even use the tables on a framing square though. Its kind of a lost art. Heck, most new squares do not even have the tables on them. It is to bad though. If you know how to use those tables you can figure out any angle, degree, or whatever you want to. Alot easier than learning algibra or trig.
TimV
03-01-2007 18:17:54
Here's one reference. Throw "span tables", "rafter tables" or even "carpenter's square" into Google and you'll come back with dozens more.
TimV
03-01-2007 18:19:43
 Re: Tables on a Carpenter's Square in reply to TimV, 03-01-2007 18:17:54
Oops--it didn't like the link. Remove spaces from this and put it in your browser.
http://www.a w c.org/ technical/ spantables/ tutorial.htm
MikeCatthemuseum
03-01-2007 17:43:12
I have an Audel's Millwrights and Mechanics handbook with a very extensive section on the framing square. Before going into a whole lot of depth, check to see what scales the squares at the school have on them. I have seen very few new squares with everything on them. With all the scales on them, you can practically send a man to the moon.
Sid
03-01-2007 17:19:13
Rafter Framers Handbook
Sid
03-01-2007 17:19:00
jokers
03-03-2007 04:25:17
 Re: Tables on a Carpenter's Square in reply to Sid, 03-01-2007 17:19:00
The older Audel`s books contain more comprehensive info regarding the use of a steel square than the new ones, which really shouldn`t come as a surprise if you think about it, everyone uses a Speed Square these days. I have a couple of really old ones that are pretty good in their description of using this tool. I also agree with the endorsement of The Roof Framers Handbook and The Steel Square by H.H. Siegel is also an excellent book.
