Tool Talk Discussion Forum
Many questions about restoration tools
Mike CA
02-28-2007 20:42:47
I turn very old on Sunday (35) and I want to get some tools for my shop I'm building to restore my '46 Farmall H. I went to Harbor Frieght, and they are having a sale, so I need some info.
1) Air compressor. I plan on painting, cleaning, etc. Maybe I'll run a few tools, but I know air tools are $$$! So, there is a big 21 gallon, 4.5 hp peak, 3 hp rated one. I don't know what this means, but 4.0 SCFM @ 115 psi / 4.4 SCFM @ 90 PSI. Its 110 volt, which I guess means it will plug right into my wall. So, what do you think? Strong and big enough for the job? Only $150!
2) Angle grinder. They have several sizes. 4.5" is the cheapest, but they also have 7" and 9". Which is best?
3) I'm sure I need some sort of sander to smooth out layers of primer and such. There is a 7" rotating polisher/sander. Or do you guys have a recommendation for something better?
4) I don't know what to get, but what tool gets old paint off of metal easy? An attachment to a grinder, or drill, or what?
Thanks for any help!
Nat 2
03-02-2007 09:49:10
 Re: Many questions about restoration tools in reply to Mike CA , 02-28-2007 20:42:47
I have the HF 21 gallon compressor. Bought it with a 20% off coupon, so I basically got the extended warranty for free. It's a HUGE step up from the 2-gallon unit I'd been using, but it's not going to do you for extended running of larger air tools. It's barely got enough to keep up with a small die grinder's demands.
For angle grinders, get one of each. At least one 4-1/2" and a bigger 7"/9" for heavy grinding. The 4-1/2" unit is handy for smoothing welds and cutting. You can replace the grinding disk with a cutting wheel, various wire brushes, flap disks or even sanding wheels.
For sanders, I love the 5" random orbital type. With 60-80 grit paper, these things will peel paint and rust off anything in short order.
Get yourself a twist-wire cup brush or two for the angle grinder to do cleanup on castings and heavy stamped parts like rims. Don't use them on sheet metal, though.
Stumpalump
03-02-2007 06:08:43
Do youself a favor while you can still hear and get some ear muffs for grinding,hamering and running any loud tool.It's cool now to wear paper dust masks to grind and resperators to paint. The palm sanders that are about 5"x5" get a lot of use in my shop too.
Joe (Wa)
03-01-2007 17:53:23
Wow 35 years old!!! I probably have a hemorrhoid
older than you.
Anyway happy B'day and many more.
Joe
MikeCatthemuseum
03-01-2007 17:51:24
I agree that the rating on that compressor is a flat out lie. Air compressors are the biggest line of BS on the face of the earth right now. A real 1hp air compressor is about 5cfm at 100psi. Using that real rating, this is barely one hp of actual compressor capacity. Don't waste your money. Keep looking.
Dave Anderson
03-01-2007 17:46:05
You asked about auctions-Just go to auctionzip.com, type in your zip code and away you go!
Mel in SW Iowa
03-01-2007 17:00:06
I find it hard to get along without a compressor
that pumps at least 14 CFM @ 90psi w/60 gal. tank. I didn't realize how good some of my air tools were until my previous 3hp/33 gallon portable that I was using for shop air quit and I
had to use an old Lindsay trailer mounted 55CFM for shop air. It only pumps to 110psi, but what a
difference all that air volume makes on tools!
One cheap tool that I wouldn't be without now
is a needle scaler that I paid $40 for at Northern
tool. It is the first tool I reach for on a lot
of restoration work. It takes off old thick paint, rust, and hardened grease quicker than
anything else. Then I hit it with a wire wheel
on a 4 1/2" grinder or the sandblaster. Use with the best eye and ear protection you can buy.
Good luck,
Mel
bva
03-01-2007 12:09:40
Got to change your line of thinkin NOW. Big 60/80/100 gal tank with slow 2 stage compressor. Something that will take care of every tool out there. Now Use All air tools for safety, convenience and productivity. Won't take long for the price of air vs electric tools to pay for the compressor.
circus
03-01-2007 11:53:12
Fortunately old tractors are thick and the only sanding needed is sheet metal. Have it sandblasted by a pro and hand sand the rest. But if not use 4" grinder are for welds. 7 or 9" grinders for leveling and bondo. DA for primers on sheet metal. Double the comp.CFM minimum to paint.
Stan in Oly, WA
03-01-2007 11:48:36
Hi Mike,
I can confirm that small air compressors are virtually useless for your intended purposes. I have a Harbor Freight pancake configuration one and a slightly larger Sears one. They will inflate tires, run a paint gun or a framing nailer that isn�t being used too vigorously, not much more. From having read hundreds of postings on the subject on this forum I�m convinced that buying enough air pressure to do what you need is a very expensive proposition, but that it makes little sense to buy less than enough.
I have much more experience with angle grinders since I use them practically every day. On the issue of whether to pay 4 to 6 times the cost of a 4� or 4�� Chicago Electric (Harbor Freight) grinder to get a Makita, Milwaukee, DeWalt, or Metabo, there�s no easy answer. Those who say you get what you pay for are people who like to have things settled in their minds. I wish it were that easy. There�s no question in my mind that Chicago Electric grinders larger than 4�� are light duty at best---and not good quality even at that. The manager of the local HF retail outlet suggested that I might be better off with a Milwaukee as he signed off on the return of the second burned out 7� angle grinder I brought back in less than a month. But I have a 4�� Chicago Electric which I have been using hard for 5 years now (as well as a much newer one that stopped working when a wire to one of the brushes came loose inside the case.)
Here are a few other things I have discovered about grinders:
1. Wire wheels, whether straight or cupped, are mostly good for throwing pieces of wire at you if they aren�t knotted wire.
2. A cupped, knotted wire wheel on a Milwaukee 9� angle grinder is the most dangerous tool I have ever used (and I�m a man who always keeps the blade guard of his worm drive saw wired up so that he�ll never expect it to be down when it decides not to be.)
3. Using a 7� or 9� angle grinder will make you tired, but you�ll get just as tired of the time it takes you to remove the same amount of metal or paint with a 4�� grinder. I�m 60 and I can still grind metal with a big Milwaukee grinder for 90 minutes or 2 hours if I lay it down once in awhile to stretch.
All the best, Stan
Rockyhawaii
03-01-2007 10:55:17
I'd stay away from their air compressors. My friend bought one and the oil window popped out of it as soon as he started it up. A month later he finally got the new glass, started it up and it promptly blew something inside the pump. It's in his trash pile now.
JackT
03-01-2007 08:49:07
Mike, first off, 35 is NOT very old. Heck, most of my best tools are much older than that! Seems to me that I recall 35 as actually being quite young. At least from my current perspective it certainly is!
Seriously, stay away from Harbor Freight tools. Its cheap to buy but most of the stuff won't last for more than a few hours of use. Find a friend that knows good tools and head to a few farm and estate auctions. They are generally a great place to get good tools at a fair price. You do need to look stuff over carefully and bid wisely though. This is a personal thing, but I've had good luck with Milwaukee and Makita tools. Bosch has been disappointing in performance and durability considering their high price tag, but I'm sure many will argue that point. In any case, as others have said, buying cheap tools is usually very expensive, especially when you consider having to replace them after a short time and the time lost when the tool breaks and you have to go get another one.
Mike CA
03-01-2007 10:50:54
 Re: Many questions about restoration tools in reply to JackT, 03-01-2007 08:49:07
I've wanted to find an auction where I could buy some tools, but I have no idea where to look. How does one find a Farm or Estate auction? Local paper?
2t2@ia
03-01-2007 11:16:41
 Re: Many questions about restoration tools in reply to Mike CA, 03-01-2007 10:50:54
Many of my tools were purchased used, some at auctions, some at pawn shops, some at an University surplus store. You need to know values, though, as frequently the used tools will sell for as much or more than an identical new tool with a guarantee.
RustyFarmall
03-01-2007 11:05:00
Not likely you will find a suitable compressor at a farm auction. Most farmers own a compressor that is suitable for airing up tires, and little else. If there is a good sized unit on auction, it will bring nearly as much as a brand new one, and you will not have a warranty.
Have you checked out craigslist.com?
KEB
03-01-2007 08:33:56
If that compressor's not running on a 30 amp circuit at 115 volts, the 3 HP rating is a flat out lie. 16 amps (80% of a 20 amp circuit) at 115 volts is around 2 HP after you account for power factor & motor inefficiencies.
I have both a Makita & a HF angle grinder. I bought the HF a couple years ago when we were moving from CA to CO. I needed one to finish a project at the old house, & my Makita was in a truck on its way to CO. I'm still using the HF grinder. Not nearly as nice as the Makita, but does what its supposed to.
I like a palm sander. I have a random orbit air sander, but rarely use it. If you buy a big sander/polisher, make sure it has a random orbit mode, otherwise you'll end with marks you'll have to take out by hand.
Keith
Jerrycpp
03-01-2007 07:55:18
Get the biggest compressor you can afford - actually, get the next size up from that. You'll never have too much air, but sure can run short of it with too small of compressor. Stick with Makita or Milwaukee and stay away from Black and Decker/Dewalt. B&D and Dewalt used to be quality but now are the same cheap Chinese junk. 4 1/2 inch grinder is easier to handle, but for heavy work a 9" is better. Try the different types of switches - I like the paddle (after I've removed that dangerous safety catch). The push-on-pull-off is too darned hard to turn off when you get it caught on something. High quality tools are the cheapest investment you can make.
nballen
03-01-2007 07:43:17
I can't knowledgably speak to all you questions, but I listen to Butch about the grinders! I have a Makita 4 1/2" that I like, have used Dad's 4 1/2" Dewalt that I can't stand. (I don't like Dewalt's paddle trigger and the toggle safety switch.)
For general grinding a 4 1/2" will be best, for smoothing large surfaces, the larger disk will leave fewer divots and ridges.
Nathaniel
Butch(OH)
03-01-2007 06:12:56
Please do yourself a favor and forget that air compressor as it is waaaay too small. There are many calculators for figuring out what you need for a compressor and tank to do what you wish to do but it all gets pretty mind boggling. My shop experience is that you need a minimum of 10 CFM at 90PSI for a compressor to be of any use besides airing up tires and forget any with small tanks if you plan to run air tools and paint guns. Two stage pumps will allow tank pressures of 175 PSI which not only stretches storage capacity for painting sanding etc but allows your impact gun to have lots of power for tough jobs. Most impacts and air tools will have little power when the compressor kicks out at 100 PSI because of line losses. I know lots of money but so is a cheapo that sits in the corner and not being used.
As for your grinder I have 4-7-9� in the shop because I get bored real quick using a 4 on a 9� job but if your only going to buy one forget HF and go to Lowes, or Home Depot and look at the 4 � offerings from Makita, Bosch, Milwaukee and Dewalt and make your choice based upon your wallet. Dollars here equals performance. Play with the display models at the store. If the %$#% safety switch on that particular is a pain to work at the store it will remain so the whole time you own it.. You never go wrong with a Milwaukee tool but I choose the Makita because I like the switch, about $65. Again, lots of money compared to HF but been there.
Get a cup brush for the grinder and use it to remove rust loose paint etc. Flap wheels work good for old paint removal as will a flexible backing with 60-80 grit paper disks. Just don�t try to use the ridged wheels made for grinding welds etc for paint removal because you will make a mess of your sheet metal or castings with one.
I use HF and the stuff sold there has it�s places in my shop. Mostly tools that are used only occasionally, not electric powered and cost many bucks if bought elsewhere. Your every day tools should be bought elsewhere.
smurph72
03-01-2007 04:47:34
Kinda off subject from your original question, but for paint and crud removal use electrolysis.
Zero effort except the setup. Run a search of the archive for tons of info on how to set it up.
Good luck on your tool search.
dcm
Nolan
03-01-2007 04:08:23
The 4.5 grinder is extremely popular, and you can find wheels anywhere. They work well, and don't tire you out. The bigger ones can move a lot more material, but are much heavier and more demanding of you. I use my 4.5" SAG frequently, my big 7 or 9" unit gets used so infrequently that I can't remember what size it is.
Don't bother with a drill for removing paint, use the 4.5" SAG. Sanding discs or wire wheels work, and have different applications. Generically, a disc works best on flat panels, and a wire wheel works best on funky shaped pieces.
RustyFarmall
03-01-2007 03:29:06
Mike, that air compressor would be good for airing up the tires on a car or light truck. It wouldn't be much good for anything else. Take a look at the air tools that you are considering, each one will have a label that states the required scfm for that particular tool. The air compressor has to be capable of supplying at least that much air.
Angle grinders--- That 4.5 inch grinder is what you want, anything bigger than that is heavy and clumsy and will wear you out before the job is done.
Buddy Schiel
03-01-2007 02:47:05
I done quite a lot of painting and mechanial work over the years. If most of your work is solo, I would look for something that puts out 10 CFM or better. If you plan on running a shop where 3-4 air tools arein use all day, you might want to get a good industrial model.
1941 farmall a boy
02-28-2007 23:42:11
Hi my dad and i have one that has 150 psi we got it at sears for 120 we can run air tools on it and we never hafe to stop for the Air compressor have you look'd on www.ebay.com Im on there all the time looking at tool's
Carson
old
02-28-2007 20:50:00
Thats not much of a compressor. For what you need and will want down the road you need more HP and more CFM. (Cubic feet per minute). The biggest you can afford the better. I own a big 2 stage compressor with a 6 HP motor on it and at times its not enough to run some of my air tools. If I sand blast I have to stop every 10 minutes or so to let it catch up with its self and most of my air tools are the same way. I can paint all day long with it but painting doesn't take all that much air to do the job
