Tool Talk Discussion Forum
Pressure washer
wkw
02-26-2007 18:40:22
Are there pressure washers available that can run with minimal water supply pressure? I would like to get one but my water source will be a 350 gallon water supply tank and my only pressure is the gravity discharge pressure. Is there a brand I can look at?
Thanks
Ken
Drumheller,Ab
RayP(MI)
02-27-2007 15:37:41
 Re: Pressure washer in reply to wkw, 02-26-2007 18:40:22
As long as your supply can supply volume needed, low pressure probably won't be a problem.
wkw
02-26-2007 19:48:46
Thanks Old, I'll start looking at the manuals on the units on display. How did you make out with the roof repairs?
Ken
Drumheller,Ab
old
02-26-2007 20:56:42
 Re: Pressure washer in reply to wkw, 02-26-2007 19:48:46
Its got a temp patch on it right now. I have to wait till it stays above 50 to do more. At least I have all the stuff to do it with so its just waiting on the weather to warm up before I get it fixed the way it should be. Back when I was doing construction we had a preassure washer that put out 5000psi or more that had a 16 HP engine on it and it was set up for a tank feed system. We had a 350 gal. tank that we used and it was set up to suck out of the tank and it didn't need to gravity system to work
old
02-26-2007 19:26:47
Theres a good number of them out there that will work just fine with that set up. Sorry I don't know the brand names but if you look over the books that come with them a good number of them will talk about tanks you buy just for that type of thing.
