First off, try a couple of things.... If your feed is too heavy, it'll jam and jump the blade. Try slacking the feed. This is usually via a screw and a spring that unload the blade to reduce blade pressure. How many teeth per inch does this blade have and what are you cutting? If you can't get three teeth in the material at once, it's going to knock out teeth and jump the blade when it hangs up. Next, how old is this blade. If it is the original Chinese blade and is more than two hours old, it's probably shot. If you have used it in materail that is too thin (see above) it has missing teeth and will hang up. A dull blade will never cut straight. If you have a brand new blade and keep having the same problems, you ned to tweak your saw, if you can... Some of the cheap saws are adjustable so you can square the blade on both directions. Get a square and straighten both the vise and the vertical position of the blade. if you can't adjust the blade, get out a file or whatever and work on ti so you can. If it still won't cut straight, it's the frame trunnion and your saw is crap. I had to scrap one that had this problem.
