Tool Talk Discussion Forum
power washer using no SOLVENT
John hunt
02-25-2007 03:22:28
I am looking for a part washer that require no solvent while clean that does a complete v 8 motor part ...
Vern-MI
02-25-2007 05:44:07
 Re: power washer using no SOLVENT in reply to John hunt , 02-25-2007 03:22:28
They are called Typhoon washers. The Waste awater is skimmed and filtered to catch the oil and debris.
Joe(TX)
02-25-2007 03:27:21
 What? in reply to John hunt , 02-25-2007 03:22:28
Is there a question or even a comment here?
john hunt
02-25-2007 03:46:02
 Re: What? in reply to Joe(TX), 02-25-2007 03:27:21
you put your part in this machine. you turn it on.. the water boil to 213 degrees. it runs about a hour, clean grease right off ,clean part!!! it getting so hard to use solvent here it by county stantard... and the state step in too,so understand what am looking for ...
Bryan in Iowa
02-25-2007 12:04:09
 Re: What? in reply to john hunt, 02-25-2007 03:46:02
Hot tank / Spray cabinet.have one in my shop . Uses non caustic soap,,or you can use caustic for cast iron cleaning , does lil better job . Waste water and sludge can be ran through an Evaporator and disposed of as a solid .
MSM
02-25-2007 05:28:21
You still have to dispose of the water,it became hazmat as soon as it was used for degreasing the engine block.6 of one half dozen of the other.
