Tool Talk Discussion Forum
generator won't generate
larryinwa
02-24-2007 04:39:00
was given a craftsman 4000 watt generator and after carb work got it running-but no juice-all wires to panel look ok-son said it worked last time used-about 3 years ago-of course i have no owners manual,any ideas?
NRM
02-24-2007 10:38:03
 Re: generator won't generate in reply to larryinwa, 02-24-2007 04:39:00
Check the brushes.
JT
02-24-2007 09:11:25
Larry,
you need to flash the generator if it has been sitting for a while. To do that plug a drill into one of the 110V outlets and turn the drill backward by hand, but be carful, if it needed to be flashed, and it works, the drill will start running and the chuck can tear up your hand. If that does not do it, the next thing probaly will be a capcitor in the end of the gennie under the cover, about 3 inches long and an inch in diameter, that after flashing is what is wrong with 95% on the ones we get it for service. What model is it, you can go to sears website and get a parts breakdown on it.
jim
Ryan - WI
02-24-2007 05:23:50
Try this.
Plug in a corded drill. Fire up the genny. Pull the trigger of the drill and give the chuck a spin. This induces a current in the drill (motor turned backwards is a generator) and back feeds into the generator.
This is usually enough to re-excite the coils in the generator and it should start producing power again.
It is a pretty common problem, especially if the generator sits for a while.
HG
02-24-2007 08:47:45
 Re: generator won't generate in reply to Ryan - WI, 02-24-2007 05:23:50
You may have to reverse direction on drill if necessary.
Midwest redneck
02-24-2007 04:54:03
I have a Companion Sears 10Hp and the capacitor or something went bad, it is a small box just under the generator cover. went bad, $15 from Mcmaster carr. Happened to me 3 years ago. (this may be it, if your lucky)
TomTX
02-24-2007 04:45:28
Might contact Sears for Operator Manual.
