Tool Talk Discussion Forum
OT- Pick-up truck gas tank- filling problems
GPWT
02-22-2007 15:19:14
I have a problem with my 2004 GMC Canyon. When I fill the gas tank I can only get about $1.00 in it before the pump shuts off. Then I have to wait 5-10 seconds and squeeze the pump handle again. The pump then shuts off after pumping only about 10 to 25 cents worth of gas. This goes on until the tank is full. The filler neck seems clear- is there a vent that is blocked? Any ideas out there? It takes about 15 minutes to fill the tank, and with our winter weather it seems like hours! This problem happens at different gas stations so I don't think it's the pumps.
Randy in pa
02-24-2007 03:22:53
 Re: OT- Pick-up truck gas tank- filling problems in reply to GPWT, 02-22-2007 15:19:14
Article from phoenix newspaper.
150 bags of pot found in pickup's gas tank
Associated Press
Feb. 21, 2007 10:34 AM
ST. PAUL, Minn. - A couple face drug charges after police say they found more than 150 pounds of pot in the gas tank of their pickup.
According to federal investigators, the couple pulled into a Midas Shop complaining about fuel problems. A mechanic noticed some suspicious weld marks on the gas tank and called the cops.
Police say the tank had a secret compartment and marijuana probably had gotten mixed in with the gas. Investigators are praising the mechanic for his "sharp thinking."
Wild Bill
02-23-2007 07:58:03
don't put the nozzel in as far
dave guest
02-22-2007 18:17:27
BTDT ford truck. Found gas station with slow pump and continued to buy gas there for the life of the truck. Was a new tank.
MikeCatthemuseum
02-22-2007 15:59:54
This is a problem with the flatbed at work. The filler neck goes very nearly horizontal before turning down into the tank. Parking on the side of the pump that puts the filler neck highest in relation the the tank helps, but still doesn't totally solve the problem.
John hunt
02-22-2007 15:54:10
you got plug in the air vent hose. or a gas hose is in bent position that it cut off air release are get a other problem beside that some type of error on the dash board.do you let go of pump handle went you pumping your gas, are you might have it in to far to the bent of filler tube... that what I found out my 2003 gmc somona pickup..
Same problem
02-22-2007 15:41:08
I've got the same problem on a 2004 fullsize Chevrolet 1500.
I've checked the filler hose,they are o.k.
Been told and read on a forum,it is most likely the VENT Valve on top of tank.Also it will do this if you attempt to fill with ing. switch on.
I see some diffrence at diffrent stations,I THINK that some nozzles are smaller.
You can find a Chevy truck forum,and find this discussed. Haven't checked on the price of thiss VENT VLAVE part.Wonder if it might be a recall???
RickL
02-22-2007 15:39:27
not sure what canyon is,is that same as chevy blazer,if it is yes you are probably not getting air. they have a foam filter that ride right above where the spare tire is carried. It is real pain as this vehicle use for mail route. Have to clean it out at least monthly Such a joke
RayP(MI)
02-22-2007 15:26:47
Had the same problem with a couple different vehicles, different manufacturers:
I have found that If I shove nozzle in as far as it will go, that's when I have trouble. Try withdrawing the nozzle an inch or an inch and a half, see what happens. Or change the angle of insertion. Has worked on several of the problem vehicles.
Eddie in MI
02-22-2007 18:12:41
 Re: OT- Pick-up truck gas tank- filling problems in reply to RayP(MI), 02-22-2007 15:26:47
I do the same thing Ray suggested and it works every time.
