Grass trimmer
C.G
04-29-2001 05:15:51
My grass trimmer will start but will only run for a matter of seconds, can anyone help
Unimog
04-29-2001 17:24:19
 Re: grass trimmer in reply to C.G, 04-29-2001 05:15:51
I had the same problem and a new spark plug was
the answer.
F14
04-29-2001 09:06:51
Check for:
Fresh, clean gas, proper fuel mix.
Gas tank cap vent working properly.
Good spark, clean plug.
Exhaust restrictions. On a two stroke (which most trimmers are) there's a spark arrester screen in the muffler that gets plugged up with carbon and exhaust residue, and that's also a favorite place for mud daubers to winter over.
Carburator properly adjusted.
ROY MI
04-30-2001 18:35:29
 Re: Re: grass trimmer in reply to F14, 04-29-2001 09:06:51
plugged muffler
charlie
04-29-2001 16:12:36
check in the tank to make sure the fuel line and filter aren't clogged.also check the primer bulb on the carb to see if it's cracked.good luck
bob
04-29-2001 19:15:42
 Re: Re: Re: grass trimmer in reply to charlie, 04-29-2001 16:12:36
also make sure fuel filter stays down in liquid i fought a chain saw untill opened cap and line about fell out also agree a spark plug would be a good start
