Tool Talk Discussion Forum
Electricity Question
Glenn FitzGeral
02-19-2007 20:57:37
How many watts = an amp?
Thanks Glenn F.
oldfarmtractor
02-20-2007 20:10:22
 Re: Electricity Question in reply to Glenn FitzGerald, 02-19-2007 20:57:37
Watt are you saying?
MarkB_MI
02-20-2007 03:29:23
Watts is a unit of power, similar to horsepower. (1HP = 746 watts.)
Amps is the unit for electic current, 1 amp equals one coulomb of charge per second.)
As the others have said, in a DC circuit or purely resistive AC circuit, power in watts equals volts times amps.
For an inductive or capacitive ac load watts no longer equals volts times amps. This is due to the phase difference between current and voltage. You must multiply volts times amps times "power factor" to get the true power in watts.
Power factor, which is the cosine of the phase angle between voltage and current, cannot be easily measured using tools most of us have (generally it's done with a phase-angle voltmeter or an oscilloscope). You either have to use the manufacturer's published power factor, or else guess. 0.7 is as good a guess as any for typical inductive loads like motors. So if you were trying to figure power consumption of a 120V motor rated at 10 amps, it would be 120 x 10 x 0.7 = 840 watts.
Bob
02-19-2007 21:07:46
Volts X Amps = Watts
Jon Hagen
02-19-2007 22:29:59
 Re: Electricity Question in reply to Bob, 02-19-2007 21:07:46
Watts divided by volts = Amps.
