Tool Talk Discussion Forum
Toro zero turn mower
NTP
02-19-2007 18:51:22
Home Depot is closing out last years model Toro 420 zero turn mowers at a good price. Anyone have any experience with these, good or bad? I have a lot of trees to mow around.
JT
02-22-2007 06:52:22
 Re: Toro zero turn mower in reply to NTP, 02-19-2007 18:51:22
It is not a bad machine, just not built for longevity. If you decide to purchase this machine from the big orange box, make sure it is set up and ready to mow grass, if it not set up and adjusted, and you take it to a local Toro dealer, you will have to pay for that service, set up is not covered under warranty, and if the big orange box tells you it is, then they are misleading you. I would check with your local Toro dealer and ask him if you buy it from the big orange box, will he take care of any warranty issues, a lot of time, they will not. And does he have any that he will sell you at the same price
lenray
02-20-2007 07:14:51
Got the TANK thinking a cub cadet co. it is very heavy and the wife loves it.
Bud in NC
02-20-2007 03:54:15
We looked at one but the dealer was familure with our neighborhood and he advised against it - Unless you're a pro and used to the steering they don't do good on steep hills. With the front wheels acting as free swivels it's hard to cut sideways and that's hard to avoid all the time. Disapointed me - I was gonna enjoy playing!
My boss lady loves mowing grass so I want her to be happy....and she would NOT be happy if she couldn't steer!
Also, we got a much heavier conventional riding Husky 50" with a commercial transmission from a local dealer for the same price Lowe's had a "homeowner" 46" model. We paid the price that was hanging on the steering wheel - no special deal - just Lowe's, HD, etc have a "special" line of mowers just for homeowners - not less money but cheaper - more profit margin for them. They look the same but their 50" mowing deck weighs about 150 pounds - ours is almost 300 pounds - much heavier gauge steel. Same with the front hubs and axels - ours are much heavier than what Lowe's had.
Lowe's & HD's are designed to last 5 to 8 years. Ours is designed to last 15 to 20 years - for the same price. Whatever you get compare what a local dealer has to offer. Maybe we just got lucky, but it's worth asking a few questions for.
rameus
02-19-2007 20:17:29
zero turns are great. But if you are doing any heavy cutting I would stay away from the ones at Home Depot and other such places they are only meant for light residential cutting and are not as durable as ones made by gravely scag and other companys. for around 1500-2000 more you can get something that will last longer and have fewer problems. I looked @ the cheap ones before I bought my gravely and am glad I decided on it. After 2 years mowing 5 acres of bahaya all it has neaded is oil changes and the blades sharpened still the same blades btw.
Hobo,NC
02-20-2007 04:52:44
 Re: Toro zero turn mower in reply to rameus, 02-19-2007 20:17:29
I got a Gravely 3 years ago and it had the floating front axle, I rigged it up so I could lock it in and it does a good job now. With the floater it did not cut even. Mite as well throw this in, I just sold my Crapsman 42� cut. It had a very good 19HP briggs engine but the transmission went south. I sold it fer $200, the guy tried to jew me down but I stood firm, I told�em I wuz give�n him the mower and only charging him fer all the welding I have had to do to it to keep it from fall�n apart and that I would not discount my time to weld it fer enny one, he got a good laugh out of that and hauled it away.
flying belgian
02-19-2007 19:21:53
If you have small sappling size trees a zero turn doesn't work very well. You want a 4-wheel steer. If the trees are 24" dia. or more than zero turn will work ok. Zero turn digs the grass out if you turn short piveting on the back tire.
JT
02-22-2007 06:47:25
 Re: Toro zero turn mower in reply to flying belgian, 02-19-2007 19:21:53
The trick to using a zero turn is to run one wheel forward, then run the other wheel backward, when turning, then it don't tear the turf at all. That is the way they were designed to be run. Been using and selling Z's for over 15 years now,If you grip the steering sticks and use them like you use a grocery cart, it will help you steer without tearing up or burning turf. that is the way I advise my custoners to turn their machines so they don't do turf damage.
