Help! need correct wiring tips for Ford 9N generator
Dave Jeffrey
04-28-2001 05:18:51
HELP! I put a new rebuilt generator on my 9N last year and still not getting a charge out of it. I can't find anyone in my area who knows how to wire up this thing, not even an auto mechanic I know. Anyway, I currently have the field terminal on the gen going to the small box (regulator???) terminal, then it goes to the "gen" terminal on the ignition switch (added by the last owner) then finally to the battery, is this correct? If this is correct is there a chance the gen is not working or is it something else?? I would appreciate any help or guidelines from 9N'ers around the country.
Thanks loads!
Dave Jeffrey
P.S. It's a 6 volt positive ground setup
DavidO
05-17-2001 09:45:28
 Re: Help! need correct wiring tips for Ford 9N generator in reply to Dave Jeffrey, 04-28-2001 05:18:51
Click on the link below. The diagram you need is the first one (2N/9N) 6V. Hope this helps.
Robert(AL)
04-28-2001 16:50:40
Go to the 8n, 9n board and search generator. There is a schematic there for a 6v generator installation.
