Tool Talk Discussion Forum
MF 2640 hi-lo speed
Bob Pete
02-19-2007 15:39:50
MF 2640 4x4 tractor The 2 speed (Hi - Lo) power shift button seldom works. Installed new push button---same problem. Checked wiring to sensor and solenoid...no visible problems---did some checks with DVM. The wire on the solenoid is very small (20 ga.) checked it and taped it up. Do I dare remove the cap on the solenoid? Can the solenoid be removed or do you have to drain the hydraulic system? There are 2 solenoids on the right side of the transmission and I think it's the one towards the front----it that correct? There sensor is on the same side towards the rear -- or am I confused about the sensor? Not 100% sure how it really works---Tried several places to get a shop tech. manual to no avail. A MF manual was over $150 and I'm not ready to go there yet. Where can I get a manual? *All help will be appreciated.
