Tool Talk Discussion Forum
Flat towing a auto trans car (need help quick)
jpuleo
02-17-2007 20:48:08
I have a 1993 escort that is auto trans. I want to flat tow it 150 miles. I understand it will damage the trans if I do this because the brarings wont be getting fluid. Is this right?
Second, my father in law is a mechanic and said its not going to hurt it if I leave it idling in N while being towed as the engine turns the transmission oil pump. Its a $500 car so its not the the end of the world if it gets damaged but I want to get some second opnions before I do this tomorow after church.
Thanks and any help will be appreciated.
jpuleo
02-18-2007 16:06:01
 Re: Flat towing a auto trans car (need help quick) in reply to jpuleo, 02-17-2007 20:48:08
I ended up getting a dolly last minuite. Thanks for all the good advice. I couldnt drive it because it wasnt registered and the steering was not working right.
Don L C
02-18-2007 10:27:27
...Adjust the idle a little faster,that way you can tow 60-65 MPH and engine will get extra oil pressure.....with engine running, put trans. in neutral....150 mi. = 3 hrs.....may cost you an extra $3 in gas.....
frankiee
02-18-2007 06:41:03
I would stop a few times and start it up and rev it up a bit. Also put foot on brake and put it thru the gears.
That just to get all the fluid to splash all over.
Bob
02-18-2007 08:53:16
 Re: Flat towing a auto trans car (need help quick) in reply to frankiee, 02-18-2007 06:41:03
Frankie,
The auto tranny's's wet clutch plates, bearings, and sprags HAVE to have a constant flow of oil to lube and COOL them.
The thing I haven't figured out... he's worried about hurting the tranny, so it must be working, and the engine apparently RUNS, so why not just DRIVE it??
Bud in NC
02-18-2007 03:59:01
Drop the drive shaft.
Vern-MI
02-18-2007 05:37:07
 Re: Flat towing a auto trans car (need help quick) in reply to Bud in NC, 02-18-2007 03:59:01
Not too easy on a FWD as he would have to drop both Rzzeppa joints to uncouple the trans from the engine.
uncle
02-17-2007 20:50:48
You can only flat tow with the engine running and keep the speed down. The engine turns the pump but at too high a speed it could still do some damage.
jpuleo
02-17-2007 20:49:04
as in flat tow I mean tow with all 4 wheels on the ground with a rigid tow bar.
Thanks
old
02-17-2007 21:12:53
 Re: Flat towing a auto trans car (need help quick) in reply to jpuleo, 02-17-2007 20:49:04
Rent a car daully there only about $25 or so and it will save you problems in the long run. That way you don't have to worry about the tranny and you will be safer also.
jpuleo
02-17-2007 21:16:49
 Re: Flat towing a auto trans car (need help quick) in reply to old, 02-17-2007 21:12:53
Yeah, I agree. Its just I have to do this tomorow and no rental place is open here on Sunday.
old
02-17-2007 21:34:45
 Re: Flat towing a auto trans car (need help quick) in reply to jpuleo, 02-17-2007 21:16:49
Well most U-Haul places have them and you could find one of them on your way and they can be picked up and droped off at any U-Haul place
