Tool Talk Discussion Forum
Troybilt Wood Splitter
Jim in NC
02-17-2007 18:01:06
The hydraulic valve lever will not lock in and allow the cylinder to return after the splitting stroke. The lever has to be held to allow the cylinder to return. Is there an adjustment for this? It worked fine for a couple of hours, but then started this little trick. Any help will be appreciated.
veggie
02-19-2007 02:38:00
 Re: Troybilt Wood Splitter in reply to Jim in NC, 02-17-2007 18:01:06
Could possibly be the little , spring loaded detent pin had the end break off. The detent cap would need to be taken off to check it out. Usually held on the back side of the spool with a couple of screws. Tom
jokers
02-18-2007 11:26:54
You might also want to change your hydraulic oil filter. When the differential pressure on the filter gets too high the detent valve will not work properly.
Paul in MN
02-18-2007 10:26:51
Jim,
My woodsplitter does that too when the oil is cold. As it warms up from use, then the viscosity is right for the detent to work.
Paul in MN
J Schwiebert
02-18-2007 05:51:17
First of all what brand of valve do you have? There will probably be a detent adjustment. If the machine only has a few hours does it have warrenty?
Jim in NC
02-18-2007 18:57:43
 Re: Troybilt Wood Splitter in reply to J Schwiebert, 02-18-2007 05:51:17
The splitter belongs to a great friend. We worked on it for about 2 hours yesterday. I adjusted that valve about every way that I could. It would trip the valve if I loosened the cover about 1/8 to 1/4 in. It was working great and just stopped all at once. I have had a wood splitter for about 20 years and it is similar to this one. I have adjusted mine before, and as said above, sometimes when cold, it is slow to work properly. I really appreciate your replies. Its gotta be something simple.
