Tool Talk Discussion Forum
radiator stop leak
ken in texas
02-17-2007 16:33:17
I also need advice on engine head gasket leak.Used silver seal but continues to seep .Don't really want to pull heads,any recomendations. Car is a ford explorer v6 single cam in block 125000 miles and runs great, Saw add for a permant sealer but havent been able to find it.thanks
Kent in KC
02-19-2007 12:03:22
 Re: radiator stop leak in reply to ken in texas, 02-17-2007 16:33:17
When I was younger, working on old forklifts, we used a product called Water Glass. Got it at the drug store. Something intended for candling eggs. It is like liquid silica. Anyway, we'd put it in the radiators of old leaky lift trucks. When nothing else worked, this stuff did and amazingly so. I've seen water leaks that looked like someone had opened up a garden hose and Water Glass stopped the leak in seconds. We never found any drawback to the stuff that I recall, it just lined the water jacket with glass, more or less. Good luck finding it.
ttman4
02-21-2007 10:50:53
 Re: radiator stop leak in reply to Kent in KC, 02-19-2007 12:03:22
Walmart out here in C. Oregon carries "Liquid Glass" in their stopleak, antifreeze department.
Don't remember what name it's called, but have seen it there recently.
dave guest
02-18-2007 19:45:49
I am waiting to see the first time stop leak works with aluminum block or head. Tried and tried and got tired.
XRogerX
02-18-2007 15:34:31
Anybody know the proper product and procedure to use to add sealer in the pressurized overflow tank system on my 99 Sable? Some products specifically state not to use them in such a system.
thejdman01
02-18-2007 08:35:35
IRON TITE, works super well. At this point, you dont have much to lose.
Dug
02-17-2007 20:48:00
I've tried the stop leak before, never again!
JayWalt
02-17-2007 18:17:49
stop leak is not the answer, do it right.
It makes a total mess of the cooling system.
TomTX
02-17-2007 17:25:14
If Explorer is in good, and you want to keep it, then consider getting it fixed properly. I you "patch" it with stop leak of some sort, it will let you down, maybe at a bad time and bad place, never fails. Tom
