Tool Talk Discussion Forum
BEST HEAVY DUTY RADIATOR STOP LEAK
Joe in MN
02-17-2007 11:08:32
When in need of Radiator Stop leak, which Brand would you use... I have heard that JB (Jutice Bros.) is Good...
Don L C
02-17-2007 18:57:08
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to Joe in MN, 02-17-2007 11:08:32
Ground black pepper --- used it on a cracked tractor block.....holding now about 10 years....
ttman4
02-21-2007 10:57:43
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to Don L C, 02-17-2007 18:57:08
I used to carry course ground black pepper with me round the country when I was driving semi cross country. Used it several times thru the years too!
Carried rubbing alcohol with me too & put in airlines/air system in winter to keep air from freezing too.
Yeah, & rubbing alcohol cost $.11 cents per bottle back then too! Could live big on $5 per week too...
Easy1
02-17-2007 17:30:02
A good rad shop.
TomTX
02-17-2007 16:19:43
Best radiator stop-leak is a good radiator shop. All those snake oil stop leaks are only of limited value for s short term patch. BTDT and then had problems with cooling system. I could have saved money and agravation by pulling it and fixing it right to start with. Tom
1936
02-17-2007 16:03:56
Bars leak! None work all that well.
NAPAGUY
02-17-2007 12:59:00
USE 104 MENDTITE MADE BY ZECOL..NAPAGUY
Joe in MN
02-17-2007 13:43:24
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to NAPAGUY, 02-17-2007 12:59:00
I called NAPA, they never heard of it... can you give me more information, where it's available etc.
napaguy
02-19-2007 07:36:46
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to Joe in MN, 02-17-2007 13:43:24
call them back...part # is 104 option #7..napaguy
CENTAUR
02-17-2007 12:15:06
JOE:Where is your leak or leaks.Please post.CENTAUR
Joe in MN
02-17-2007 12:29:26
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to CENTAUR, 02-17-2007 12:15:06
To Answer your queston,,, the out side boiler I use is loosing water more then normal, so there must be a leak on one of the welds, soooo--- have to apply stop leak until I find and fix.
CENTAUR
02-17-2007 13:02:47
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to Joe in MN, 02-17-2007 12:29:26
Joe:That boiler answer changes everything.While there are many good products out there I do not know which is best for your problem.Iron-tite,J.B.Weld,Devron,etc. each seem to make differant formulas.CENTAUR
thejdman01
02-17-2007 11:50:06
IRON TITE google it.
old
02-17-2007 11:18:00
I've always used bars leak but even then it just a stop gap cure at best but it does work for a while
Little Ed
02-17-2007 11:16:47
There are some tablets that you get from GM that are all organic. just crumble them up and put in your radiator. I have only used them short term, so I don"t know how long they last. but they have never failed to work for me.
sojono
02-17-2007 12:12:41
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to Little Ed, 02-17-2007 11:16:47
ground black pepper in an emergency.
BigMarv1085
02-17-2007 16:42:57
 Re: BEST HEAVY DUTY RADIATOR STOP LEAK in reply to sojono, 02-17-2007 12:12:41
I agree with the product Ed's talking about. My relatives worked at Ford and they put 2 of those big organic pills in every radiator of a new vehicle.
