Tool Talk Discussion Forum
Walk behind snowblowers ?
Mike M
02-15-2007 12:41:30
Which type do you perfer ? The ones with tires and chains or the ones with the rubber tracks ?
Anyone ever use both ?
Tim B from MA
02-17-2007 20:28:20
 Re: Walk behind snowblowers ? in reply to Mike M, 02-15-2007 12:41:30
I have a Honda 11/32 with tracks, I have only used wheeled machines for a short time. My opinion is that, unless you have a steep section of drive that you need to blow, the tracks aren"t worth the extra cost and turning effort.
I would look for hydrostatic drive and quality components on the blower itself. For example, the mechanism to turn the shoot ought to be a worm gear (Honda) or a cable (Ariens?) not a twirled, pig tail rod (Troy built)
peterak
02-16-2007 23:54:46
my two cents, i have been running tracks for the last 18 years. i have 2 now 5/22 honda close to wore out. newer 11/32 honda. the coolest part is that they climb, stairs to deck, level to level sidewalk , into truck. the little one you can muscle around 3rd gear wide open. the big one is more point and shoot. i am an extreme snowblower, about 600' of driveway at home and about half that at cabin. about 76" of snow this season so far.
peter
jeffcat
02-16-2007 09:50:57
Just for fun in South Jersey. We don't get that much snow but I have a 1962 Model "L" Gravely with the old I think 28" blower. Boy dose that thing BARK! Hehe Jeffcat
zacsdad
02-16-2007 08:12:17
used sno-hogs, no chains for a long time....never had a problem. Have done some pretty deep snows (one was about 28" and almost taller than the blower throat). Never tried tracks.
Harvey1
02-16-2007 03:17:28
My experience has been, tires with chains work best.
landlord7012
02-15-2007 15:41:55
Tracks were a short lived fad. Sno-hog tires, no chains (unless you experience frequent ice). Way to go. Track machines won't "free-wheel" like wheeled machines.
ll
JoeK(WI)
02-15-2007 21:33:04
 Re: Walk behind snowblowers ? in reply to landlord7012, 02-15-2007 15:41:55
Yep,tracks are good for traction,but hard to manuever in close quarters.Snowhogs and chains if needed work better.For a short time in early 2000s Cub Cadet(MTD)made a 4WD(I have one).2 Sno hogs on ea side with steering assist brakes like a track drive,but easily freewheels.
Just a note,if your're buying new,make sure the handle height is high enough so your're not hunched over.A lot of the machines out there are too short for taller operators.
