Tool Talk Discussion Forum
air supply lines
Russ Vetter
02-13-2007 18:17:41
I am getting ready to build my shop up and wondered if anyone has any input as to running air lines from the air-compressor to various locations around the shop. I have never had a shop with multiple rooms before and I plan on putting the air-compressor in a back room to lose the noise. I have seen PVC pipe, black pipe, and copper tubing used and was wondering which one would be the best value and still be good for some heavy duty work. I know about putting drains at the ends of each drop and most of the other techincal things; just need some input on materials. Thanks
T.C. in Tx
02-14-2007 20:32:34
 Re: air supply lines in reply to Russ Vetter, 02-13-2007 18:17:41
Here is a quote from the Plastic Pipe Institute website:
"PEX-AL-PEX is widely used in residential and commercial plumbing and in pressure service on compressed air and compressed gas systems.
PEX, and PEX-AL-PEX tubing are typically joined with metal fittings; CPVC tubing with solvent weld fittings. All of these components are readily available and inexpensive. Plastic tubing does not require soldering or special threaded connection."
Pex-Al-PEX has an aluminum component. None of the PEX tubing should be used where sunlight can weaken them.
Kem Groeschel
02-14-2007 19:48:04
Use metallic piping only for compressed air lines. PVC lines can and will shatter upon impact- creating dangerous flying shrappnel. PVC is attractive, available everywhere and cheap. Synthetic oils embrittle PVC piping causing it to crack and break. Do not use PEX as this is designed for water piping only. Your choices are copper(best,cleanest and most expensive), then galvanized pipe, then black pipe. Most factories around the country use black pipe - add drain legs on pipe drops to remove condensate.
I am in the mechanical contracting business and deal with this stuff daily. Do the right thing and stay away from PVC.
MF294-4
02-14-2007 18:37:46
If anyone has info on PEX tubing for air lines, I would like to know more about it. I haven't been able to find any info for air.
Charles (in GA)
02-14-2007 13:32:40
The only plastic pipe that is actually rated for compressed air, and approved by the California OSHA and accepted by US OSHA and most likely all state OSHA's, for compressed air use, is ChemAire, manufactured by Nibco. It is an ABS based plastic that will split if damaged or fails, does not explode into shreads like PVC. It can be glued or also is available with push lock o-ring fittings.
Certain type of copper tubing is strong enough if soldered with the proper type of solder, go to the Copper Development Association's website and download the Copper handbook, to get the charts and other info on Copper tubing for all uses. Excellent resource.
Link
Charles
brainded
02-14-2007 13:14:14
I just use garden hose it swells up real big and gives me more air storage.
flying belgian
02-14-2007 07:53:45
I used pvc. had it in for about 20 years now with no prob. compressor set to 160 psi. but after reading messages I think I will change to black pipe. I always wanted to go with larger lin and this would be good time. should use 1" if you are going to use 3/4 impact other wise you cannot get enough air to it. also large line gives you more tank capacity as there is more air stored in line.
Aberdale Farm
02-14-2007 07:16:53
I just finished doing the same job in my new shop. I used black pipe. Metal is better than plastic for air lines because it is a good thermal conductor. (Plastic is a thermal insulator). The metal pipe allows the moisture to condense out of the compressed air faster, reducing the possibility of moisture ruining your air tools. Although galvanized might not rust as quickly, I've never heard of black pipe rusting out in air line applications, especially if you drain the downpipes regularly. If you decide to use galvanized, I would make sure to filter the air good for the first few weeks. It's not uncommon for the loose galvanizing to flake off the inside of the pipe.
Good luck!
Dale
Russ Vetter
02-14-2007 06:18:14
Thanks everyone for your input! I also did not intend on using PVC for the same reason listed above. Does not seem too safe, I did not think of galvanized pipe so I'm glad I posted this. Will start to look into prices today. I have a couple of Oliver tractors that can't wait for me to get this shop done so they can get some TLC. Thanks again everyone!!!
RickL
02-14-2007 05:56:05
go with the pipe period,I done several years ago and no regrets,its no that hard to install either. Just make sure install flex hose from the compressor to the line first thou. I made mine out of hyd hose. Also on the drain petcock at the bottom of the tank I removed it and installed a air hose ther instead and use it for the line to the outside and when you do that it also drains the main moisture out of it.
Dusty
02-14-2007 05:28:42
It will take longer to install but I would use galvianized, will not rust as quick and can look nicer.
evielboweviel
02-14-2007 05:55:04
 Re: air supply lines in reply to Dusty, 02-14-2007 05:28:42
better use good filter stations at each drop with galv. pipe
ron
Midwest redneck
02-14-2007 02:28:06
OSHA has says that PVC air lines are against code, (or their rule book) (May 1988 was when the code was written) Use Black pipe instead. There is a product called PEX or something that is a heavy plastic and is suited for air pressure. I know that PVC would be fast and easy and look nice but PVC explodes like shrapnel and could kill somebody, like you.
T.C. in Tx
02-13-2007 19:37:59
You may want to check out PEX. I did a bunch of research last summer before I installed the air lines in my new shop. PVC gets everyone excited because it may shatter if it is hit. Copper is very expensive. Black pipe is a bear to install.
The PEX that I used is the same one for water lines. Got the fittings at Lowes. I used the kind of fittings that takes a copper ring to compress. Takes a special $100 tool to do that. But in all the fittings I installed not a single leak at 100 PSI. Fairly easy to run the lines, bends fair without needing a 90 degree fitting and so on.
Of course I have only had mine in place just less than a year, but I would do the same again.
Jerrycpp(WA)
02-14-2007 07:39:16
 Re: air supply lines in reply to T.C. in Tx, 02-13-2007 19:37:59
Tell me more! I thought PEX would blow too. I have it in my in-floor heat, and it's great to work with. I contacted a PEX distributor and asked about using it for air and never heard back. Where did you get your information that it's okay to use with air?
430WLPG
02-13-2007 19:27:10
PVC can EXPLODE without WARNING with very SHARP srapnell
Dave_Id
02-13-2007 18:35:20
Check the archives. Lot's of discussions on this, but the consensus pretty much is black pipe to be the best. I had pvc in schedule 40 in my shop and didn't have any problem on normal use, but when I was doing heavy duty sand blasting, I got unbelievable amount of moisture in the line. I left the moisure separator slightly open on the sand blast unit, because I would have had to stop every five minutes to empty the water.
old
02-13-2007 18:32:50
I've seen all of those but I have also seen copper blow out and PVC blow out and neither is pretty when it happens. Go with steel pipe that is rated at that type of pressure of better to be safe.
