Tool Talk Discussion Forum
Need the Maytag Man
CBBC
02-13-2007 15:37:04
OT, but my coveralls get washed in the machine so it should qualify.
My 4 or 5 year old Maytag Performa Washing machine is shaking bad on the spin cycle. It actually walks itself out from the wall. It shook so bad the other day the volume (presure?) hose came off - water came out the connection and then overfilled the tub. What a mess!! I fixed that problem.
The machine is level with the feet - but it still shakes and rocks. I told my wife to make sure she puts in even loads and not too full. (She is pretty good - but we do a lot of washes):). It doesn"t seem to make a differance.
Is there some sort of stabilizing arm on the motor ot agitator I should be checking.
Any advice would be appreciated. I don"t feel like spending another $500 + for a new machine.
Thanks, Grant
CBBC
02-14-2007 08:10:26
 Re: Need the Maytag Man in reply to CBBC, 02-13-2007 15:37:04
Thanks guys,
I'll check latter and let you know what I find.
Grant
TomR Ont
02-13-2007 17:05:53
Check the tub, open the lid move tub as far as possible side-side top-bottom, if it moves more than an inch or two and it's the same as mine, there is 4 rubber-plastic stabliizers near the top that stop the tub from moving too far if 1 or 2 break then it will walk. Not a hard job, costs about 6.00 each CDN + tax + tax. I replaced all 4 and kept the 1 good one as a spare.
old
02-13-2007 17:03:54
Most have springs inside of them to keep things lined up and if one of them go bad it will cause that problem, or one could have broke where it mounts also
K-Mo
02-13-2007 16:13:34
Try www.repairclinic.com or www.davesrepair.com
