Tool Talk Discussion Forum
Stihl Chainsaw
Todd in S Ohio
02-11-2007 19:26:53
This is the place I turn to for answers, so here is my latest trial and tribulation. I have a Stihl 029 that is about 5 years old. If I put it on full choke, it will sputter on the first pull. Move to half choke and it will almost always start on the second pull and run fine. However, if I shut it off, or it happens to die (not warmed up enough), it will not start again, until it sits for at least 20-30 minutes. The weather does not seem to be a factor, 50 or 5 it runs the same way. Any suggestions from the experts out there? Any help would be appreciated since I heat with wood and it doesn't look to be gettin any warmer any time soon. Thanks and stay warm.
DitchWI
02-14-2007 10:58:34
 Re: Stihl Chainsaw in reply to Todd in S Ohio, 02-11-2007 19:26:53
Todd, I have the same saw and the same problem you have I had. The fuel line is shot and needs to be replaced. They say the line collapses and the saw will not get enough gas. Took mine in and they fixed it for something like $35.00.
DitchWI
jeffcat
02-12-2007 09:36:57
A lot of good replys here. Carb kits solve a lot of problems after saws have been left with old gas in them. The new gas is another problem. Use oil with the stableizer in it and use fresh gas. In your carb, that little pile of rubber parts get stiff so the kit will fix it. Another thing is chainsaws will flood REAL easy. I hold the throttle open and pull a couple when it is hot. Jeffcat
Louis Fuller
02-12-2007 07:58:34
Probably fuel line where it accordings around between top of tank and carb.
Butch(OH)
02-12-2007 07:49:10
Hard starting when warm is almost always a flooding problem but have heard of cases where a weak ignition would cause it. I would start by checking the spark when warm and then a carb kit, newer fuels are very hard on the older carbs. Kit can come from Stihl or aftermarket and isnt a whole lot of money.
IH2444
02-12-2007 05:48:14
Well I don't have a Stihl but on an old poulan a guy give me with the same symptoms , I put a carb kit and new fuel lines in it and problem solved.
mwfarm
02-11-2007 19:38:50
Change your spark plug. Might be the problem. My 026 won't start at all right now, but I think that it is the fuel line being restricted.
woodbutcher
02-12-2007 04:12:35
 Re: Stihl Chainsaw in reply to mwfarm, 02-11-2007 19:38:50
My Stihl is about the same age, and I've had a similar problem. Mine seems to be flooding. It starts on the second pull every time. After running and killing it, it will not start if I give it any choke. I have to hold the trigger and pull the rope with the choke open or it will flood. Butch
Todd in SE Ohio
02-12-2007 04:51:17
 Re: Stihl Chainsaw in reply to woodbutcher, 02-12-2007 04:12:35
Yeah, that is exactly what mine is doing. After cranking on it, you can smell the fuel. The question is, how do we fix it? Is it simply a matter of carb adjustment?
dan hill
02-14-2007 04:29:52
 Re: Stihl Chainsaw in reply to Todd in SE Ohio, 02-12-2007 04:51:17
Check the fuel line for leakes.
woodbutcher
02-12-2007 09:24:31
I blame my problem on operator error. As long as I remember not to choke it after I run it, I can consistantly start it by holding full throttle with no choke. If I choke it at all I can count on it to flood. I have learned that I can't adjust the carburetor to correct a problem. (and neither can most parts changers.)
Carburetor is a French word that means "leave it alone."
Butch
TomR Ont
02-12-2007 13:32:36
 Re: Stihl Chainsaw in reply to woodbutcher, 02-12-2007 09:24:31
woodbutcher You'r right....
"As long as I remember not to choke it after I run it,"
I have an 034, when 1st starting cold with the choke on full and trigger locked, if it coughs like it was going to start - TAKE THE CHOKE OFF and lock the trigger on. I can pull my guts out and it won't start if the choke is on at all.
Good saw other wise.
woodbutcher
02-13-2007 04:44:18
 Re: Stihl Chainsaw in reply to TomR Ont, 02-12-2007 13:32:36
I agree, Tom. I've had the same experience. It is a very good saw.
Butch
