Tool Talk Discussion Forum
WATER TANK WITH A BLADDER
Joe in MN
02-10-2007 17:25:42
WHERE CAN A WATER TANK BE PURCHASED THAT HAS A REPLACEABLE BLADDER. THANKS FOR YOUR HELP.
Unimog
02-11-2007 13:41:38
 Re: WATER TANK WITH A BLADDER in reply to Joe in MN, 02-10-2007 17:25:42
I bought an 80 gallon one from Sears which has a
replacable liner. It looks like replacing it would
be a real pain to me. This is my second tank of
this type from Sears and the first one lasted 25
years so I bought another instead of replacing the
liner.
Hal/WA
02-11-2007 17:23:22
 Re: WATER TANK WITH A BLADDER in reply to Unimog, 02-11-2007 13:41:38
The bladder in my Sears tank went bad, and I was going to try to replace it. When I got in there, I found that the inside of the tank was rusty. I figured that the new bladder would wear out fairly quickly on the less than smooth surface, and it looked like it would be a real trick to get the new bladder through the kinda small hole at the bottom. I ended up buying a completely new tank. The Sears tank lasted nearly 20 years, but the last 5 of those years, I had to add air occasionally. I hope I get that good service from the replacement tank. Good luck!
oldfarmtractor
02-11-2007 13:04:51
You can get them at any home supply store. Get the most simple one you can. Mark my words, the next pump you get will be a variable flow and the pressure tank will not be that significant.
T_Bone
02-11-2007 20:14:54
 Re: WATER TANK WITH A BLADDER in reply to oldfarmtractor, 02-11-2007 13:04:51
Hi OFT,
I was just reading about the new constant pressure deep well pumps yesterday. They use a microprocessor that controls small differences in a pipe header with pressure sensors and a 2gal bladder tank that speeds/slows the pump to satisify constant pressure. Adjustable from 35psi to 65psi. About $2000 for pump & controls & sensors.
They listed others for higher pressures, 150psi max? I dunno as I only read about the smaller units.
My thoughts are it's costly to run. The pump has to kick on every time water is called for so it uses more electricity and I wonder how long the pump will last.
Mfg. stated it's just like being on city water. LOL Then move back to the city dummie :)
T_Bone
coup
02-11-2007 10:55:53
bought a water tank yesterday,,it said guranteed 5 year . already lost my receipt..
Dusty MI
02-11-2007 04:46:18
I got one from Grainger with replacer bladder. Replacer it once, when it needed replacing again they were no longer available. Bought a new one from Lowe's.
Dusty
Pete-IN
02-10-2007 20:04:59
If you are talking about a water well pressure tank, I replaced mine a year ago. Got it at Home Depot. It has the replacable bladder. Also, Rural King had them, but HD was cheaper. A pressure tank usually lasts so long that I doubt if replacement parts will be available that far down the road.
dave guest
02-10-2007 18:13:52
Hot water boiler. If bladder is bad replace tank and bladder which has a precise air charge in it. Do you have Grainger stores. Or a surge tank upstairs or attic-uses no bladder.
