Tool Talk Discussion Forum
Florescent fixtures??
JoeK(WI)
02-10-2007 16:27:30
Local store is replacing all(25-30)surface mounted double bulb 8ft fixtures in the store w/recessed lighting.These use the single pin bulbs.Believe I could scrounge a couple/four for my shop if I wanted to.Question is,Do I want to?Could they be 220 or likely to be 110?They are in good shape,store is being remodeled w/dropped ceiling.
shannon from ohio
02-11-2007 09:35:41
 Re: Florescent fixtures?? in reply to JoeK(WI), 02-10-2007 16:27:30
Check on ballast to see what voltage they are. If 277v you can operate them on 230v but with small decrease in light output... If you can get them for free I"d grab whatever i could,You can always sell the rest..
buickanddeere
02-10-2007 20:42:51
If are not T8 fixtures, leave them in the store.
dave guest
02-10-2007 18:16:02
Probably 120, 240 or 277. If you get them get lotta extra tu bes, they cost a bit more.
billybrown
02-10-2007 16:36:12
they maybe 120 volt or 347 volt you'll have to check also if they are t12 or t8 t12 is non energy eff, poor light output
t8 is energy eff, high light output
JoeK(WI)
02-12-2007 08:58:07
 Aww.Ratspit.... in reply to billybrown, 02-10-2007 16:36:12
Got beat out by a local farmer,28 120V fixtures w/bulbs and 2 boxes of spare bulbs goin to brighten his dairy barn..... ...Oh,well,it's a good cause and better than the landfill. He will let me know if he has leftovers :)
