Tool Talk Discussion Forum
frozen water lines
coup
02-09-2007 15:04:39
i got the lines un frozen,,but the jet pump continually cycles on and off whenever the spiket is turned on....thinking it over i think i should have splurged air from the pump itself...i tried to put air in the tank and found the rubber tire valve had a small leak,,can these be replaced or are they hooked to the bladder...i screwd the cap on and it leaked so little ,,i told her to use water sparingly till i check it out tomorrow...
Fred45
02-09-2007 18:53:39
 Re: frozen water lines in reply to coup, 02-09-2007 15:04:39
You need to get air in your tank or your motor will burn up from the cycling on and off. If it does this cycling very much your motor will be gone. I WOULD NOT RUN IT UNTIL AIR IS IN THE TANK. Been there, done that.
Fred
Charles (in GA)
02-09-2007 15:36:43
The tank is why the pump cycles like it does. It has to have the tank and air head to operate properly. If you have a tank full of incompressable fluid (water) is it like having no tank at all. Since fluid is incompressable, the pump cycles on, builds pressure in an instant, cycles off, the water, not holding the pressure due to its incompressability, depressurizes instantly, the pump again cycles on, and off and on and off.
If this is a bladder tank you need to set the pressure at about 2-4 psi below the pressure that the switch cuts ON at. This will assure you that you still have a flow of water when the pump comes on. If you get the tank pressure above the pump switch cut in pressure, the flow of water will stop and finally the pump will cut in, very annoying. Use a very accurate gauge and measure the pressure the pump comes on at. Turn off the pump, open a faucet and leave it open, use this same gauge to measure the pressure you have in the tanks bladder, and as I noted, set it two to four psi below the switch pressure.
If you have water in the bladder then it is bad. A few tanks actually have replacable bladders and valves, most don't. Proper air charge will go a long ways toward a good working well system, and get you the most water out of the faucet between pump cycles.
Charles
Mark-in-Mi
02-09-2007 18:17:36
 Re: frozen water lines in reply to Charles (in GA), 02-09-2007 15:36:43
Charles hit the nail on the head.
