Tool Talk Discussion Forum
Vinyl siding material
gcs
02-09-2007 12:57:10
I"m presently cutting strips out of vinyl siding for a project, this is a PITA,lol
Is there a vinyl material or a similar substitute that can be obtained in rolls, either 4 or 6" wide?
The stuff needs to be thin, waterproof and long lasting,... like, vinyl siding. :)
Thanks, George
Stan in Oly, WA
02-09-2007 19:22:31
 Re: Vinyl siding material in reply to gcs, 02-09-2007 12:57:10
Hi George,
At the community college where I work all the welding booths have curtains made of 6" wide strips of some colored transparent plastic material which is fire resistant and blocks infrared (or is it UV?) rays. They were recently replaced because the old ones looked so raggged and worn out. Out of curiosity I cleaned up several of the old ones and found that they were largely unaffected by 40 years of heat and light from welding arcs as well as weld spatter and hot slag. The new ones were delivered in the lengths we ordered but probably any lengths and widths are available.
All the best, Stan
Areo
02-09-2007 19:08:17
How much and big must the pieces be? If not that big you can rough saw and then cut to size on a sheet metal shear or cut with a tip snips.
Areo
old art
02-09-2007 14:18:10
yes they make rolls to find where look for an industerial supplier they can help you get some information whom makes the product.it may help even if you look on the box the sideing comes in.
do you need a lot or a small amount they may have waste that would fill your needs.
