Tool Talk Discussion Forum
Stihl 028,How to split case halves
Redtom
02-08-2007 17:18:53
Whats the best way to separate the two halves of the crankcase on a 028? The guy at the shop said to tap them apart. They're loose, but evidently the crank is pressed into the bearings and the bearings into the case. Is there a puller like I once used on a motorcyle 35 yrs ago?
Shovelman
02-08-2007 17:55:48
 Re: Stihl 028,How to split case halves in reply to Redtom, 02-08-2007 17:18:53
Stihl made a tool for that purpose. It bolts to the bar studs and has a pressure screw that pushes against the end of the c/shaft.
After the crank is pushed out of the drive case half, you can put the mag side half in the press and push the c/shaft out.
As JD stated, a little heat makes bearing removal/installation easier.
jdemaris
02-08-2007 17:42:07
I was a Stihl mechanic - but before the 028 came out - so I can't speak on that saw specifically. But with all the other Stihl saws with magnesium crankcases - e.g.020, 040, 041, 030, 031, S10, 075 Lightning, etc. - you first drive out the locating pins, then heat the crankcase area around where the bearbearing is pressed in until it gets loose enough to pull the halves apart. If I get around to it, I'll dig through my Stihl service manuals. I took most home when our tractor dealership closed (we sold Stilh saws and Deere tractors).
