Tool Talk Discussion Forum
HF Parts Washers
Glenn F.
02-06-2007 23:22:32
Enjoying detailing/mechanical work as I do, I've always thought a parts washer would be nice. I don't have any lot number or anything, but Harbor Freight has had the same one on display for some time. Any of you have a HF washer? Any good?
Thanks, Glenn F.
BigMarv1085 in Ga.
02-07-2007 02:42:38
 Re: HF Parts Washers in reply to Glenn F., 02-06-2007 23:22:32
I have used several of them. Seem to work better with kerosene. The pump goes out when you use commercial solvents. $149 for a 40 gallon or 30 gallon that sits on a barrel.
rwp
02-07-2007 16:11:30
 Re: HF Parts Washers in reply to BigMarv1085 in Ga., 02-07-2007 02:42:38
I have one, but I left the solvent in it and it took all the paint off on the inside. Quite a mess to clean up. So now when I get through using it, I drain it into a couple 5 gal. containers and then strain most of the dirt out.
