Tool Talk Discussion Forum
Pressure Sand Blasting
DumOleBob
02-06-2007 17:38:57
I"ve got a 48", self contained sand blast cabinet, but every now and again I need to clean things over 48" wide so I am thing of a pressuer balster. They seem to come in cheap, and expensive! From a hundred bucks at Harbour Fgt to thousands of dollars. What does a guy look for? I want something that"ll work, but not overkill. All tips sincerely appreciated!
DumOleBob
old
02-06-2007 19:56:42
 Re: Pressure Sand Blasting in reply to DumOleBob, 02-06-2007 17:38:57
I have 2 of them. Ones a $12 one from wal=mart which works good for small jobs and a $79 one from harbor fright. Problem is the $79 one the bottom vavle clogs easy so I jsut removed it and it now works well, holds about 40lbs of sand
Stumpalump
02-06-2007 18:49:52
Ever see the humongous trucks they use to sand blast a bridge? Get a small one and you will know why. You want overkill especially on the air compressor because the use a lot of air non-stop.
1250jd
02-06-2007 18:22:08
I have a 40# blaster from Harbor Freight. I have sand blasted 2 tractors with it and had no major problems. I do have a large 2stage compressor that provides sufficent air.
