Stan, Question 1) It sounds to me like the service is a 480 Y 277 Volt, 3 Phase 4 Wire grounded. When the three secondary transformers are wired and configured that way in a Y, the voltages would be 277 from any one phase to the center common tie point Neutral, while it would be 480 (277 x 1.732) volts from line to line. Thats a typical industrial service in which case lights can be fed and balanced as three legs of single phase 277 volts (Line to Neutral) and there is still 480 volt 3 phase available for large and motor loads. The common center tie point is grounded at the pole (or pad mount) and the service entrance. The wires ran out for a lighting branch circuit would consist of a Hot, a Neutral (grounded conductor) , and a Equipment Grounding Conductor, which is similar to a 120/240 volt single phase 3 wire set up BUTTTTT TTTTT more voltage obviously. Another typical 480 volt service would be a 480 volt 3 phase 3 wire Open Delta, but it could only suppy 480 NOT any 277 volts. Actually the 277 is good cuz theres less amperage and less heat and I Squared R losses in the feeders. We used to see it often... Question 2) 240 DOES NOT EQUAL 208. The 208 volts is derived from a 208 Y 120 Volt, 3 Phase 4 Wire grounded Y System. In it there is 120 volts from any single line phase to the common center tie point Neutral, but its 208 volts (120 x 1.732) line to line. It has three legs of single phase 120 volts for outlets and lighting etc and 208 volt 3 phase for larger 3 phase type loads like HVAC. The typical residential service is 120/240 volts Single Phase 3 Wire which has 2 legs of 120 VAC single phase (Line to Neutral) and 240 volt single phase (line to line). NOWWWWW WWW theres one other way to measure 208 volts, and thats on a 120/240 volt 3 phase 4 wire high/red leg delta that has one of the 3 transformers center tapped. On that service the 240 volt single and 3 phase loads are line to line (its 240 across any transformer) and the 120 volt single phase loads are fed from the 2 line to Neutral connections on the center tapped transformer. BUTTTTT TTT from Neutral to the other high/red leg phase, there would be 208 volts..... .. Hope this helps, Best Wishes n God Bless John T Retired Electrical Engineer
