Tool Talk Discussion Forum
Interior House Paint
Glenn FitzGeral
02-06-2007 09:38:15
This summer I hope to finish off my garage, (wiring, insulate, sheeting, etc.). I have accumulated many gallons of high quality "off white" paint. Will this work as my base paint, in place of primer? Sheeting will be drywall ceiling and probably 1/4" plywood walls.
Thank you, Glenn F.
Don L C
02-07-2007 20:14:48
 Re: Interior House Paint in reply to Glenn FitzGerald, 02-06-2007 09:38:15
--- I have found "SEARS"best hard to beat.....Don
sojono
02-06-2007 12:20:28
latex works fine on drywall but i always use oil base kiltz on wood for primer to prevent bleeding then u can use latex over that.
charles(mo)
02-06-2007 16:55:57
 Re: Interior House Paint in reply to sojono, 02-06-2007 12:20:28
I haven't used Kilz primer in years. It is a good product but you need to be well ventilated and use a good respirator. At least that was my experience. That stuff just about wiped out all my brain cells.
rhouston
02-06-2007 13:25:00
you could hit all the knots with shellac before you hit it with the latex. That should keep the bleed through to a minimum. I don't know what sealers you have on hand poly may also work if that's all you have.
Matt Smith
02-06-2007 10:01:04
Yes.
