Tool Talk Discussion Forum
Tecumseh 6.5 revisited
Rod in Smiths F
02-05-2007 14:53:15
Today I tore the the dead 3.5 B&S off an old lawn mower, modified the chassis (new holes and one cut-out) to accept a Tecumseh 6.5 which I bought on sale for $88.00. The one I selected was shiny and red but seized, so I freed it up with a pipe wrench after soaking the rings with hydraulic oil. It had an inconvenient horizontal drive shaft sticking out so I cut it off with an angle grinder. It would fit the existing holes on the chassis if I mounted it backwards but I opted for new holes and got it on mostly forward. The safety lock transfered to the new motor, as did the blade and its hardware. I added oil and took it outside, where I hurriedly gassed it up and started priming before the oil cooled and turned to taffy.
It started and blew oil for a while until the cylinder cleared itself. Then it settled in very nicely, indeed. I ler it run for an hour interrupted by frequent checks of the oil level -- dipsticks are tricky on those things -- and then I headed for the barn with it, mowing snow. A 6.5 hp on a regular mower blade is very, very hard to stall.
Anyway, we now have a utility lawn mower for places the big hydraulic one can't go, at a cost of $88.00 plus taxes. My labour I wrote off as a hobby activity.
Traper and Vern, your warnings about the new motor proved accurate and useful. The dip stick is tricky. I spent a chilly hour today getting the oil level right. The brake was right where you said it was but it connected to the interlock system on the old chassis, so it wasn't a problem.
JT
02-06-2007 06:27:15
 Re: Tecumseh 6.5 revisited in reply to Rod in Smiths Falls, ON, , 02-05-2007 14:53:15
You have a nice engine there. Keep a few thigns in mind if you plan on having this for a while. This engine needs to be primed very slowly, with a 3 count between primes, and the most important thing, This engine does not like gasahol, it will not be nice to the little rubber parts it the carb. 10% will work, but it still does not like it, anything over 10% will cause you problems.
