Tool Talk Discussion Forum
Hylomar gasket sealant
JCHesler
02-04-2007 19:38:16
I've been using Hylomar as a gasket sealant in the last many engines that I've rebuilt. Over 10 years of service and it's doing a real good job. I like the stuff but can't find it anymore. NAPA never had it. PepBoys is where I've always gotten it (only reason I'd go into a Pep Boys store) but they don't carry it anymore either. I think it's a British product but licensed to Permatex for sale in the US. Anyone know where I can still get it without sending to England at $49 a tube?
electro
02-11-2007 08:37:49
 Re: Hylomar gasket sealant in reply to JCHesler, 02-04-2007 19:38:16
was once the only stuff to use on Mersedes(sp) and VW diesel head gasketts.
Jonathan in MA
02-06-2007 04:15:32
"Hylomar 101" is used extensively on alot of the new small Deere engines. It is used as a stand alone--- no gasket-- in a lot of applications..So if you have a Deere dealer nearby they "should" have some..
jokers
02-05-2007 19:06:10
I`ve never used Hylomar but it sounds an awful lot like Loctite 515 anerobic sealant. 515 works extremely well as a replacement for cylinder base gaskets on chainsaws.
Glen in TX
02-05-2007 11:50:07
I hated the hylomar stuff but maybe what dealer had was always old too. Was a waste of money once and never used it again. The gray or black permatex and other new ones they have work well as do their old line ones of indian head shellac, aviation sealer, & hi-tack.
JHesler
02-05-2007 19:04:27
 Re: Hylomar gasket sealant in reply to Glen in TX, 02-05-2007 11:50:07
Yeah, thanks for your input Tex but I think I'll go with the opinions of the others.
Stickler
02-05-2007 08:12:56
Come to canada...hylomar is still very common and readily available here.
Bob in AZ
02-04-2007 22:28:22
That was good stuff . We used to use it when I worked at the Jag dealers . All the manufacturers just went to silicone sealers and the Hylomar fell out of favor . Plus it was expensive !
What I've found that works very well is the Permatex Grey silicone sealer. It really bonds to the metal/gaskets well and doesnt leak . It is superior to the blue , orange and other silicon sealers . When you apply it you can feel it bite into the metal surfaces . A lot of the others just slide across the surface .... you know that stuff isnt going to seal . Its about 5 bucks a tube , not bad .
Another good sealer I've found is at the motorcycle dealers . Yamabond , or Kawasaki Bond works excellent . Kind of a greyish white goop in a tube and it really seals well .
Hope this helps some as a substitute .
Bob
Greg_Ky
02-04-2007 19:46:25
Permatex has discontinued their licensing of Hylomar. Here is a link that is still available.
Roy Suomi
02-04-2007 19:43:40
Years ago I used Hylomar...Great stuff..I bought it from a company in Cleveland , Ohio named PAI [parts associates inc.] I don't know if they still handle it or not , but it's worth a phone call..I haven't seen a salesman since Roger Allen in the 80's..
